LG LHD45EL Dehumidifier Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The top of the dehumidifier is icing up and the present % window always says high instead of a number. I never seem to have to empy the bucket. Can it be fixed?
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Mar 07, 2011
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10836827
Points
101584
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Empty bucket,put back in, unit won't restart
this is a very ,very common complaint I get from folks on these , seems the shutoff float is most times part of the bucket (you take it with you to M/T tank) and it gets a little molested in the fervor(splashing) of getting a heavy tank over to M/T out , a few minutes of looking careful at it (top of tank) and most folks figure out what went wrong with it and snap it back where it goes correctly ( most machines use this same switch to confirm presents of tank installed) this makes it proof positive that there's a tank to drain water in instead of going all over the floor
and option is to convert the unit for constant M/T tube most units come with a kit for this
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
2helpful
2answers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
2answers
I have a comfort air dehumidifier that does seem too effective. also theer is a tube on top of the water bucket? whats that for?
That's the water collection tube, that drains water into the bucket. What's the other other problem that makes it seem, that the dehumidifier is not to effective?
Can I hook this up so itd empies directly into the floor drain?
yes, there should be a bucket that fills with water, on the outside of the bucket, there should be a cap you can screw off, once off you can attach a garden hose to that bucket and the other end goes in the drain.
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
2helpful
GoldStar DH504EL Dehumidifier
Your dehumidifier should have come with a tube which would allow you to do this very easily. I beleive the part number is 5214A20027B.
Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
