Question about Canon PIXMA MP530 All-In-One InkJet Printer
CHECK CARTRIDGE u052 - Canon PIXMA MP530 All-In-One InkJet Printer
Posted by dennisky66 on
philpot
    New Friend:
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Posted on Mar 30, 2013
  • philpot Mar 30, 2013
Brian Lee
    Scholar:
    New Friend:
  • 110 Answers
Join the class action lawsuit. It is very close to being settled.
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Posted on Jun 24, 2015
5 Related Answers
Mohamed Omran
  • 2567 Answers
SOURCE: Got a
This problem can be resolved by either of 2 ways:
1. Installing the Print Head and Ink Tanks 2. Reseating the MP530 print head
Posted on May 15, 2009
Chris Yelton
  • 708 Answers
SOURCE: Hi their
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
Posted on Nov 19, 2009
Testimonial: "thanks!"
Anonymous
  • 787 Answers
SOURCE: my canon mp530 printer had a check cartridge error
6800 must be EEPROM error.Try this:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (you're still holding the POWER button during this). The printer mechanics will move momentarily. You're in SERVICE MODE now.
Press the RESUME 3 times.The lamp will alternate color with each key press.Then press POWER button.Wait 5 mins and press POWER again, the printer will turning off.
If this not help printer may need service.
Posted on Oct 15, 2009
Anonymous
  • 787 Answers
SOURCE: mp530 u052
Try press and hold reset button for 5+ seconds.
Posted on Nov 24, 2009
Anonymous
  • 5 Answers
SOURCE: check cartridge u052
u163
Posted on Oct 25, 2010
Error message U052
U051 indicates an ink cartridge that cannot be recognised by the printer. Sadly you cannot use your printer while this error remains.
I would advise the following:
-Remove the problem cartridge from the printer
-Wipe the gold contacts on the front of the cartridge with a piece of non fibrous tissue (like kitchen tissue).
-Re-install the cartridge.
If the error remains it is likely that there is a genuine problem with the cartridge. So I would advise getting in touch with whoever you purchased the cartridge from to arrange a replacement.
Sep 04, 2012 | Canon Office Equipment & Supplies
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
MP 170 check ink
U051,U052,U053,U059 all are signal or Error is mean CHECK CARTRIDGE
The Fine cartridge may not be install properly,or the cartridge may not be the compatible with this machine.Install and appropriate the fine cartridge.
Dec 03, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp530 u052
Nov 24, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hi their My MP530 printer reads CHECK CARTRIDGE U052, the manual does not help, can anyone help me please?
Nov 19, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printing Error...
Hi!
The U052 error means that the 'chip' fitted to the Cartridge is not responding . They fit these chips to try to prevent refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and the chips are particularly sensitive to static / damage. Many people end up blowing the chips during the swap over
Please rate this solution.
Thanks
Rylee
Feb 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 U052 Error
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
3,728 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
