Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I need to find parts for a Mr Slim MS15TN - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Posted by jonathanraus on
4 Related Answers
Anonymous
  • 128 Answers
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
Anonymous
  • 340 Answers
SOURCE: mr. slim air conditioner does not cool.
maybe just a cleaning
Posted on Jun 19, 2009
Anonymous
  • 3 Answers
SOURCE: i need to clean the blower part of my Mr. Slim ( the cylinder )
mr slim has this cover. just unscrew the whole cover and you've got the visible blower. the power supply must be turned off so there is no electic shock or accident that other person may turn the a/c. then there is this cover of the fan with a lock so unlock it and you can clean it throughly with a cloth.....
Posted on Dec 08, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
I need an evaporator control board for Mr. Slim Model MS 18 NN Where can I order this item ? Please help. C.J. Leslie
Here you go
http://www.expertappliance.com/mitsubishi-mr-slim-parts.html
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Seeking user manual as air conditional switched off after 10 minutes running. Air conditioner is a Mitsubishi Mr Slim controller PAR-JH050KA
Please check temp setting -4 degree than your room temp and mode in " cool" .Due to overheat in compressor also air conditioner switched off after 10 minutes. If condenser dust block clean it. If less rpm in out door fan, replace fan capacitor.
For your manual request, get it from:
homeappliance.manualsonline.com/manuals/.../mitsubishi/mitsubishi_air_conditioner_product_list.html
Helpful?
Dec 30, 2010 | Mitsubishi MS15TN Air Conditioner
I have a mr slim old unit mod# MU15SN and the unit cycle off after 15 mins of running time even though tme room temperature is above 80 deegre what could be the problem
These little uits sometimes have a compressor overload protection device mounted on top of the compressor. It could be malfunctioning or the heat is to great in the outdoor unit.
I would clean the outdoor unit and then replace the overload switch,
hopefully that will solve your problem
Jul 14, 2010 | Mitsubishi MS15TN Air Conditioner
My Mr SLim Model MS12TN indoor unit is leaking, I cleared the outside hose, I have cleaned filters, run dy mode, what causes this. I pourchased unit in May 2005
well this units have sort of a goo like foam tape that holds the coil in place it sounds to me that part of that is allready damage and the water is running down the coil and out of the drain pan the only way to fix it is to replace that foam tape.
Jun 02, 2010 | Mitsubishi MS15TN Air Conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I need to clean the blower part of my Mr. Slim ( the cylinder )
Dec 04, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Apr 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
199 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
NOEL
NOEL
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
