Question about LG Heating & Cooling
LG B30AWY fault code ch 12. air con unit not working. any ideas???
Posted by pete_d_ryan on
R Subramaniyam Iyer
  • 2,133 Answers
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Posted on Feb 07, 2011
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
Error code ch 61
try cleaning the outdoor unit with a hose pipe. the err code is caused by high pressure on the outdoor unit. please also check if the fan outside runs when the compressor is on, if not the fault is probably caused by the fan or fan capacitor being faulty.hope this is helpful.
Mar 04, 2016 | LG Heating & Cooling
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Sep 01, 2015 | LG Heating & Cooling
Error code "ch12 for LG PQRCUSA0
Connect the remote controller cable to
the wired remote controller installation board as shown in the right picture. 12V SIG GND Red wire Yellow wire Black wire 12V SIG GND 4. After fixing the
top part of the remote controller to the installation board as shown in beside picture, press the bottom part to assemble the controller to it's board. When
disassembling the remote controller from the installation board, use the driver as shown in the right picture and insert it into the hole with the arrow. And
when you pull the driver in the front direction, the remote controller will be separated. Wall Side Wall Side ENGLISH Red Yellow Black Remote Controller
Cable ?The remote controller cable is connected as factory default. Wall Side Wall Side 2. After fixing the cable to the guide slot, attach the wired remote
controller installation board at the desired location.
Mar 02, 2015 | LG Heating & Cooling
I have an LG mini split system, when I turn the unit on with the remote a code flashes on the wall unit 32 CH
do you have the owners manual? this is a fault code never worked on an LG mostly fujistu samsung
Oct 21, 2013 | Heating & Cooling
Error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Feb 03, 2011 | LG Art Cool LA181CNW Split System Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
1,906 people viewed this question
Top LG Heating & Cooling Experts
Steve F
Bill Long
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
