Sony Ericssin W810i not able to detect Bluetooth device Plantronics Voyager Pro Bluetooth Headset ? Tried with Nokia mobile to search the device but same issue, please help
Once the LED shows alternate Blue and RED then u can search the bluetooth device with your mobile and mobile can easily search it and can connect with deviceOnce the LED shows alternate Blue and RED then u can search the bluetooth device with your mobile and mobile can easily search it and can connect with device
You can't post conmments that contain an email address.
Oftentimes there may be interference from other bluetooth devices on the
phone. Disable them first, disconnect the battery from the phone for 30
seconds (helps to reset) and follow the pairing instructions from the link below.
Because this is a discontinued model going with a very new phone. I
hope it works for you. Otherwise you may have to purchase a new headset.
However when they discontinued that they did not make a replacement.
You may want to look at the Voyager Pro HD. Plantronics Voyager 510 Pairing Instructions
Making sure the headset is fully charged, you'll probably want to try
and pair the headset to your phone again. Make sure that any
bluetooth devices are removed from the phone. Removing the battery (if
possible) for about 15 seconds helps to reset the phone. Follow the
pairing instructions on the link below for the Plantronics Voyager
Pro.
Listen to music with the Plantronics Explorer 220:
Unfortunately the Explorer 220 was not designed for music, it does
not have the technology built in to stream audio. Headsets must have
the Bluetooth A2DP profile and technology to be able to stream music.
Like the Plantronics Voyager Pro+ and BackBeat models. Here are the
links for these below.
Unfortunately this is a common occurrence. We say one name and it
says, "did you say..." something totally different. I think that most
of us has had that experience. The Bluetooth headsets that have a
longer "boom" type mic will pick up your voice better and have a better
chance at hearing your voice properly the first time. Models like the
Plantronics Voyager Pro+ and the WG100/B have a boom type microphone.
The WG100/B also includes a UBS Bluetooth adapter so it can be used on a
pc.
Try to re-pair the headset to your phone to make sure that it has a good
connection. Before running through the pairing process, be sure to
totally delete the headset from the Blackberry's menu. You may want the
headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics
Voyager Pro headset into pairing mode by holding the power button until
the headset flashes red and blue. Here is the link below for the
Voyager Pro pairing instructions. Plantronics Voyager Pro Pairing Instructions
Once you make your iPhone discoverable, then put the Plantronics
There could be interference from other Bluetooth devices on your phone. I
would delete or disable them from your phone. You can also try taking
the battery out of the phone for about 30
seconds and then try relinking the two. User guide listed below.
