Canon Copier IR2018 Error E808 - Computers & Internet
Posted by manavbookstk on
specialistel
    Brigadier General:
  • 8,909 Answers
Error 808 is a fan/cooling fault. Maybe one of the fans has jammed?
Posted on Feb 07, 2011
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/travis_e264b9f3ca4047ae
Jul 30, 2014 | Canon Office Equipment & Supplies
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
Where do i find the fixing film?of the ir2018 canon printer. what does it look like and how do i replace it? [email protected]
hi,
please do following
m good with laser printers but when it comes to copiers. ... I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. ... Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot. ...
www.copytechnet.com/.../canon/41455-canon-ir2018-fixing-film-replacement.html - Cached iR2018 fuser replacement... Repost for mnamono‎ - 7 posts - 27 Oct 2010
IR 2018‎ - 9 posts - 20 Apr 2010
More results from copytechnet.com »
May 30, 2011 | Office Equipment & Supplies
Canon copier IR2018, error808
E808-0000 Fixing drive circuit failure
Main Cause/Symptom:
- The heater does not turn on.
- A fixing drive motor failure was
detected.
Countermeasure:
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 07, 2011 | Canon Office Equipment & Supplies
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
I want user manual of Canon ir2116J copier
conon IR2116J printer E001 and E808.Please help me.
Oct 27, 2009 | Canon imageRUNNER 2000 Copier
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Jan 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Computers & Internet Logo
526 people viewed this question
Ekse
Marvin
Marvin
