Question about Haier Washing Machines
Hello I have a haier washing machine HNS1260TVEME and it is leaking from the door. I think it is the gasket retaining ring. How do i put a new one on? Cheers
Posted by newjamerz8 on
Robin Bonathan
  • 699 Answers
There is a clamp on the inside of the machine that holds it in place.
You have to access the clamp screw from either the top or bottom of machine depending how it was installed originally.
Posted on Feb 07, 2011
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Need to reinstall gasket
Unplug the machine and carefully pull the edge of the door gasket near the door opening. Put the lip of the door gasket properly over the lip of the door opening. Check that it is properly seated before putting back on the retaining hoop around the lip of the door opening and the gasket. Replace the retaining hoop if it holds the door gasket loose.
Feel free to update me about the result and if you need further assistance.
Jan 24, 2010 | Maytag MAH8700A Front Load Washer
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
Aug 01, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Replacing door gasket
Depends on which machine you have but essential it is all the same. There will be a ring on the outside of the seal( outside of the machine) take that off and fold the seal ove into itself. Or even fold it into the drum. Than you can reach the retainer ring on the outside of the drum. remove that one and replace in the opposit sequence.
Aint to hard but just a little annoying to do.
Good luck
May 31, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
May 01, 2008 | Bosch WFMC 3200 Front Load Washer
Rubber gasket Bello!
Apr 29, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
