Question about Sharp Televison & Video
My sharp TV have encountered a green screen what shall i do?
Posted by rodolfo_jose on
Jdvillanueva
  • Sharp Master
  • 2,098 Answers
Hi Rodolfo,
Your problem is internal, this is due to the following reasons :
1. Bad drive transistor on the neck board.
2. Mis-aligned trimer resistor on the neck board.
3. Dry joints on the neck board.
4. Tube is faulty.
5. jungle ic
Isolating the defective parts is technical. I've advice you to send it to repair shop to troubleshoot the symptoms.
Hope it may help you.
Thanks for using Fixya.
Posted on Feb 07, 2011
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
What shall do when i encounter "finisher out of service error"
Well you could power off the machine disconnect the finsher phyiscally and electrically and then power on the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 17, 2015 | Sharp MX-2700N Color Copier
Sharp tv
removing flyback lines by adjusting the FBT "Screen" trimmer measuring 4000 to 5000 DCV from G2 at CRT socket pin. Check RGB transistors in CRT board circuit to remove green screen.
Jun 20, 2014 | Sharp 32C-240 32" TV
19" sharp no picture just green screen
it may looks its your video board..
is your tv LCD SHARP?
Feb 09, 2010 | Sharp Televison & Video
Green screen with software update
phoned sharp who told me the main circuit board had gone. so new tv required.!!!!
May 28, 2009 | Sharp Televison & Video
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp lc46d64u screen has vertical green lines
Unfortunately my friend, there is not a whole lot that can be done. Sharp has a great limited warranty, but it does NOT cover ANY problems due to physical damage. Getting screens replaced often times cost more than the tv itself. Save yourself the trouble of getting pissed off at sharp because they wont help you if you decide to call and replace the tv. Good luck 2 u
Feb 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
