Question about Zebra Z4Mplus Label Printer
How do I load the labels - Zebra Z4Mplus Label Printer
Posted by musmom on
Paulo Rangel
    Champion:
  • Zebra Expert
  • 285 Answers
1st unther the crome plate
2nd up the sensors (left)
3rd betwen printhead and with rollar.
Posted on Mar 26, 2011
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Zm400 just keeps on spitting out blank labels even after a hard restart
It's possible the labels are not loaded correctly and are missing the label sensor. Be sure the labels are loaded all the way to the left, if you are looking at the front of the printer.
Jun 16, 2011 | Zebra ZM400 Thermal Label Printer -...
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
Can not reload lables in the gun
Depending on the type of gun that you have, loading will vary. Here is the most common style of label loading:
Loading
  • At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.ixzz18ERFHy
  • Dec 16, 2010 | Office Equipment & Supplies
    Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
    CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
    May 18, 2010 | Zebra Stripe S600 Thermal Label Printer
    My machine keeps reading
    Sounds like you may have inadvertenly loaded the ribbon underneath the label sensor, blocking it, and making the printer think it's out of labels. Check the ribbon path to make sure it's loaded above the label sensor.
    Hope that helps !
    Apr 27, 2010 | Zebra Z4Mplus Label Printer
    I CANT LOAD THE RIBBON AND LABELS AND THE PRINTER DOESNT RESPOND
    It does look a little strange inside, but here's the manual:
    http://tinyurl.com/yb2rpd4
    Loading the Media, p 12
    Loading the Ribbon, p 17
    Be sure the ribbon comes off the spool clockwise, and the labels come off the spool counterclockwise. Look carefully at the pictures in the manual and you should be able to load it ok.
    Also be sure to close the printhead (the purple handle that holds down the ribbon and labels) to the 6:00 position when you're done. Then close the covers, turn it on and try it out.
    Hope this helps you! If so, please leave a rating.
    Mar 15, 2010 | Zebra Stripe S600 Thermal Label Printer
    Labels are out
    load the labels properly
    Sep 25, 2007 | Zebra Printer 140-751-00000
    Zebra Z4Mplus Label Printer Logo
    27 people viewed this question
    Top Zebra Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Marvin
    Marvin
    Ekse
    Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
