SOURCE: how to format a Dane-Elec so Ready 500GB drive
if you can see it . use a xp,vista,or any other setup disc and format it that way.put in disc format the disc and then when it has formatted remove disc before it puts the system on.
SOURCE: My Dane-elec 4GB usb flash drive , no drivers?
Try it in another PC, if the same its a writeoff.
SOURCE: Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
SOURCE: Is the dane elec 2gb drive compatible with windows
generally yes, the Dane Elec drives work fine in windows 7, i have 2 of these drives, 1 512mb and 1 8gb, and they both work fine in
windows vista
windows 7
Linux
Macos
