Question about Whirlpool Duet GHW9150P Front Load Washer
Service light on my wfe1075bd 7.5kg whirlpool front loader is on and it wont allow me to do anything
Posted by nigel241 on
5 Related Answers
woobie dog
woobie dog
  • 1273 Answers
SOURCE: replace the bellow in my front loader whirlpool washing machine
Hello. You don't need any special tools to do this. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, making sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll find different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you. Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
Posted on Aug 18, 2009
Marty marty
  • 883 Answers
SOURCE: whirlpool front loader
please clarify the "some times throughs the switch" part...does the timing switch continue to run even though the machine stopped?
Posted on May 25, 2007
Anonymous
  • 251 Answers
SOURCE: SERVICE MANUAL
whirlpool.com is where u can get a manual for ur washer Helping one preson at a time Shaun
Posted on Nov 17, 2008
sac_guy41
  • 107 Answers
SOURCE: f3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
Posted on Nov 12, 2009
Anonymous
SOURCE: whirlpool front loader 6lhw0050pq washer won't
replaced belt
Posted on Jan 09, 2010
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
Hi I have a whirlpool front loader, the door open light is flashing and machine wont operate. if I turn the machine of at the power source it goes off but after the machine attempts to start the light
You don't want to be spraying those locks with anything, unless it's an electronic-approved spray. They are electronic and can short VERY EASILY. My advice would be to have the lock replaced.
Apr 29, 2012 | Whirlpool AWM6100 Front Load Washer
I have a front loader washing machine. WFE1075BD and the clean pump light keeps coming on. I can't find my manual. Could someone please tell me how to clean it and what to do. Thankyou
There is a drain catch at the bottom of your washer. Remove the kick panel at the bottom of the front of the washer. There is a 2" diameter plastic drain cap that you can screw off and then clean the drain catch behind it.
Nov 09, 2010 | Whirlpool Washing Machines
Kenmore front loader lock door light off washer wont start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&$$##
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Service light is on my whirlpool washing machine and won't allow the wash to start, can I override this as it's only 18 months old?
The main motor in the whirlpool front loaders has brushes. These will wear out eventually. Does the drum try and turn when a load is started? If not the motor deserves a check. 18 months sounds short but possible. Mine took 4 years to wear down.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Need to undo control lock on duet front loader?
Press and hold the end cycle signal button for three secounds.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
165 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
