You could contact Archos, but I gather their minimum cost for repair is $85. Plus shipping and parts. A suitable hard drive would probably be around $100. Amazon has a new Archos 7, 8gb wifi + 16GB microSD for around $200. While the memory is smaller it is more rugged and better suited than a hard drive for a portable device.
If you are charging it only through the usb be aware that it can take up to 10hrs to charge. If you are using a dock it takes 3-4hours. When it is is charging the green light on the side should be solid. It will blink when fully charged. If it falls outside of the above described please exchange it at the location you bought it if possible or contact archos for further assistance.
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone. 2 options 1. Back to Archos 2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Same thing happened to me and I freaked out. Sit it on the charger overnight and then try to turn it on. Basically, what happened with mine was I had completely drained the battery to the point that, even though it was charging, it didn't have enough juice in the pack to turn itself on. If this doesn't work, then try resetting (use the end of a paper clip to push the "button" next to the area where the USB plugs in. If that doesn't work, try Archos tech support.
Hi have you got your power supply plugged into the charging platform??, It would appear you have insufficient charge in the batteries on the 605.
If you have the USB lead plugged into the charging cradle this would normally ask you to select either charge or usb.
What does the CHG. light on top of the 605 do when you plug the unit into the cradle ?? (steady green-- charging. flashing green-- fully charged)
Hi if the unit has been on charge that long it should be fully charged.
With charging supply connected what is the (CHG) green led doing. (on top of 605) Flashing---fully charged. Steady---charging.
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
