Question about Vizio E421VA 42 in. LCD TV
I just bought the Vizio E421VA and I am contemplating take it back. The volume levels are horribly inconsistent. On some channels I can have the volume level at 2 and its loud, on others you put it to 20 to hear the voices. Watching movies the voices are hard to hear over the background music or sound. I have tried turning off the SRS TruVolume and it didnt make much if any difference. Is there any other options to adjust levels of the volume rather than the 4 options in the menu? I would rather not return the tv.
Posted by corey_cochra on
mccookie2
    New Friend:
We have had the same problem and I suggested to Hubby that we had better return it soon. He did some research and we are trying this: use the TV remote and press the center button "Select", Choose Audio, Make sure True Volume is set to On. I've only been watching for an hour but it very well may have solved the problem. Hope it works.
Posted on Feb 26, 2011
  • 1 more comment
  • mccookie2 Mar 02, 2011
    FYI, no it didn't work :( The volume problem is maddening.
  • mccookie2 Mar 04, 2011
    I put the True Volume back to Off and it seems to be fine now. Go figure.
  • nosamiv Apr 04, 2011
    i'm having the same problem with our new vizio e421va. we've only had it a couple of days and i'm constantly having to turn the volume up and down. it's driving me nuts! after reading your comment, i just turned our truvolume OFF, and it already seems a little better. i would not have thought of that. i was thinking the truvolume on this set must be malfunctioning and was considering returning it. now i wonder if somehow the truvolume on/off indicator is switched, or is the truvolume feature just so poorly designed that it actually makes sound levels worse?
My Vizio 39 Tesla E421VA with no remote is still stuck in setup language screen so how can I get it off
use the volume and channel buttons and press source or menu to accept. should be on the left side of the tv.
Jun 11, 2017 | Vizio Televison & Video
How do I fix my Vizio TV model E421VA? Details are below. It has a black screen and no audio.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 01, 2016 | Vizio Televison & Video
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
Vizio E421VA shuts down immediately after turn on
They are not usually available except by authorized service centers as no parts are really sold and only circuit boards are available in most cases.
May 23, 2012 | Vizio E421VA 42 in. LCD TV
Some channels are snowy and some are clear and sound is not good on some channels as well.....i got the tv from a person who was having same issue so they gave it to me so i could get it fixed so was...
We literally have 1000s of LG TVs at work ranging from 32"-42" and beyond. Our joke is that LG stands for Little Good. We have to pay a few hundred dollars to replace the tuner board inside.
Jul 15, 2011 | Vizio E421VA 42 in. LCD TV
I just bought a Vizio E421VA last week. When trying to change the picture settings (brightness/contrast) using the Vizio remote, sometimes it just turns off all of a sudden. This also happened while I...
Hello, my name is Dan Busa with DISH Network. I happen to have seen this with other Vizio TV sets and would be very interested in taking a look into this. Even if you have resolved this please e-mail me at: [email protected]
Daniel Busa
DISH Network
Customer Service
Mar 21, 2011 | Vizio E421VA 42 in. LCD TV
I have a E421VA Visio TV. The sound seems to cut out. If you change the channel and then change it back the sound comes back. Is there some firmware update that can fix this problem? This is my second...
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to
buy them from, and they sold online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Vizio E421VA 42 in. LCD TV
Where is the audio output on my vizio e421va lcdhdtv. it doesnt seem to have an audio output just in puts.
simply doesnt have an output at all some do some dont yours does not route the audio signals to an A\V receiver instead
Dec 20, 2010 | Vizio E421VA 42 in. LCD TV
Vizio E421VA 42 in. LCD TV Logo
1,701 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
