Turn the volume down? Feed it cleaner source material? The following conditions will cause the Protection LED to go on: • Initial power-up: For approximately five seconds after initial power-up, the protection circuitry is activated and the speaker output is muted. If everything is operating normally, you will hear an audible click at the conclusion of this brief period, as the protection circuitry is deactivated and the S1500 / S2000 begins delivering signal to connected speakers (at which point you'll hear a click). It is normal for the Protection LED to fade gradually after the amplifier is powered off. • Overheating: A temperature sensing device in the S1500 / S2000 will cause the protection circuitry to be activated (and the Protection LED to go on) whenever the operating temperature of the unit rises above a safe level. To guard against this problem, make sure the S1500 / S2000 receives adequate ventilation on all sides and that both the front and rear panels are unobstructed. • Severe overcurrent conditions: This occurs whenever the signal being input to the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion). • Shorted speaker cables: This will occur if, due to faulty wiring, the hot and ground signals being output by the S1500 / S2000 short one another. • Output impedance drops below 2 ohms: This can occur if the S1500 / S2000 is connected to inappropriate speaker systems (see the "Setting Up and Using Your S1500 / S2000" section on page 5 in this manual for more information). • DC voltage detected at speaker output: The most likely cause of this is an internal failure. In general, any time the Protection LED lights up (other than during the approximately five seconds following initial power-up), there is reason to be concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully check all wiring and external devices in order to locate and correct the condition that caused the LED to light up in the first place. For further assistance, contact your local Samson dealer. If purchased in the United States, you can call Samson Technical Support (1-800-372-6766)
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
between 9 AM and 5 PM EST.
