Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
I have a inground pool, It seems there is a leak somwhere in the jacuzzi jets. I real don't use the jacuzzi part that often. Is there a way to cap off the jet holes. rather thatn going through the expensive of fixing.
Posted by frostyblu41 on
US Parts Center
  • Jacuzzi Master
  • 719 Answers
Currently there is not a solution for capping off the jets in a jetted tub.
Posted on Feb 08, 2011
Jacuzzi hot tub replacement jets
your local jacuzzi dealer should be able to source you some parts , but i can tell you if it's only a o-ring failure these are avail from your local hardware store , as most jets are rebuildable , some are not look at back for screws to see if they are or not
May 20, 2014 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I do have inground pool 16 *32 10 feet deep at one end and 4 feet at front, The pump did not start at all when i started it. Since the pump is an old pump above 15 years old I decided I would buy a new...
I'd suggest the 1.5 HP Hayward Super Pump, model SP2610X15. It's layout makes fitting it into the footprint of the Jacuzzi easier since it's ports roughly line up and are smaller in spread than the jacuzzi. Any pump will require some monor replumbing; the Haywards should be the least intrusive.
Another good choice would be the Pentair Whisperflow in a 1.5HP with or without the variable spped features.
John
May 01, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
Ray vac pool cleaner seems to lack enough power to stay on the wall
Clean the bottom screen first.
Where the hose hooks to the wall you have a finger screen either in the wall or sticking out of the wall. Ether way pull that out and clean it.
Chech all of your hose floats and jet's make sure none leak and check the float inside the head. Good luck.
Sep 09, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
The blower turns on intermittenly by itself on my inground spa
It sounds like the circuit board has a bad blower control relay which kicks on intermittenly. If the blower off button is pushed, the blower shuts off, right? Sometimes the problem is in the blower itself, but very rare. The spa should be on a dedicated circuit as stated in the installation manual, no with the pool.
Mar 27, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
284 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
