Question about Kenmore 23022 Top Load Washer
The agitator seems to be partially stripped. How do I remove it from the machine?
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
Agitater will not rotate around...seems stripped...how mdo i remove?..form top? or bottom?
Assuming this is a kemore,whirlpool washer:
Remove top cap and innner cover. Remove 7/16 bolt and pull up on agitator.
Oct 27, 2009 | Washing Machines
The agitator seems to be stripped and not spinning as usual. I can apply down pressure with teh lid up and it works but when teh pressure is removed it just sits there.
HI, this can be repaired by purchasing an agitator kit from the manufacture or, an aftermarket circuit as well. This kit will be shipped with everything you will need to repair the agitators functions.
Jul 09, 2009 | Washing Machines
Washer doesnt agitate but spins and drains
Replace the agitator drive coupling dome under the agitator. It is stripped out from overloads.
Jul 05, 2009 | GE WBSR3140DW Top Load Washer
The agitator on our roper washer seems to have spaeated in the middle as the bottom half still agitates but the top now does nothing but sit there.
there are what they call agitator dawgs that have probably stripped out, think i might have saw a video on how to repair them on you tube (search whirlpool agitator repair). simole enough to do you will need to remove the agitator using a 7/16 socket. Part number 80040.
Oct 12, 2008 | Roper Washing Machines
Loose agitator on Whirlpool Ultima Care II washer
it could have stripped the spline on the plastic agitator. there is a bolt at the middle of the agitator and you can access that thru the top . remove the top cover and you can remove the bolt using a deep socket.
once you remove the agitator you can look at the dog agitator. these a 4 pcs plastics that works like a one way wrench.
be careful on the location, they are very hard to put back.
check also the spline on the inner part of the plastic assembly.
they do get stripped.
if they are, replace the whole agitator.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Washing Machines
GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Oct 22, 2007 | GE WDSR2080D Top Load Washer
Kenmore 23022 Top Load Washer Logo
136 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
