Question about White Sewing 1418 Mechanical Sewing Machine
The needle will not go up and down, seems to be frozen, what is wrong?
Posted by dfklan on
Hans Pearson
  • 2,510 Answers
Can you move the heedle up and down by hand and is the motor running? If yes, is the clutch for the bobbin winder not disengaged?
Posted on Feb 06, 2011
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
Pfaff 1222 E Makes a whirring noise, wheel won't turn
How long has it been since it's had a thorough cleaning & oiling (including the internal moving parts)? Resist trying to run the machine if the only thing running is the motor. You could burn up the motor or possibly break a gear.
The following method has helped me rescue some frozen older Berninas (which your model seems to resemble). This method worked on all of them except one that also needed a cracked gear replaced.
Oct 31, 2016 | PfaFF Sewing Machines
I have an Elna SU. I cannot get my cam stitches to work....what could I be doing wrong? I have followed the manual.
If your machine is mechanical, not computerized, it probably needs a thorough oiling with fresh good quality sewing machine oil. The old oil has solidified over time and locked the moving parts in place.
Oct 26, 2016 | Elna Sewing Machines
Help! I can't move the needle position on my bernina record 530-2
Search the Internet for information for your earning 530-2 record.
Sep 07, 2017 | Sewing Machines
5417 Mechanical Sewing Machine: ok when my needle goes down it seems to hit someth...
If the needle is not in all the way it will bottom out in the shuttle, or if you bought new needles and accedently got the wrong ones. If the needle does not enter the needle plate far enough to be bottoming out then the machine is out of time. You know i was about to hit post it and I realized I didn't think about, if the needle is bent it will hit the hook. so check those things hope it works out.
May 18, 2010 | Singer 5417 Mechanical Sewing Machine
White Sewing 1418 Mechanical Sewing Machine Logo
138 people viewed this question
Top White Sewing Sewing Machines Experts
Colin Stickland
Colin Stickland
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
