Question about Bunn B10 Coffee Maker
Tank lid gasket may be bad,fill basin could be cracked.Contact Bunn on-line.You can go to there website.You may want to call customer service,sometimes there is a replacement program.
Posted on Feb 11, 2011
Oct 02, 2014 | Bella 13600 Coffee Maker, 12 Cup
Jan 09, 2013 | Keurig Elite B40 Coffee Maker
Problem:
Keurig
B30 would only brew a partial cup and stop. Had to run 3 times to
complete brewing.
Solution:
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
Apr 17, 2011 | Keurig B30 Mini Coffee Maker
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 21, 2010 | Keurig B50 Coffee Maker
Apr 28, 2010 | Keurig Elite B40 Coffee Maker
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Jun 05, 2009 | Bunn NHB Coffee Maker
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Oct 02, 2007 | Saeco Vienna SuperAutomatica Coffee...
102 people viewed this question
