Packard Bell Speaker Computer Speakers Logo
Question about Packard Bell Speaker Computer Speakers
I have no sound and it sayd Your computer does not have a sound card, or a sound card is not selected. its a packard bell 1502
Posted by robert_ecob on
5 Related Answers
Anonymous
  • 131 Answers
SOURCE: Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
Posted on Jan 05, 2008
Anonymous
  • 2351 Answers
SOURCE: packard bell utow co20
Please look on the case of the PC, fron back & sides. There should be a model number. (There is no such number you posted, Packard Bell UTOW CO20).
Mike
Posted on Jul 06, 2008
proton77
Mandeep Singh
  • 1184 Answers
SOURCE: i need to factory restore
The best step forward , would be to call Packard Bell Tech support and get your CDs for the same. There is no reset feature on the computer.
Thanks
proton
Posted on May 26, 2009
Anonymous
  • 585 Answers
SOURCE: packard bell utow co20 the computer will stay on for as long as I dont use it, but as soon as I start useing it it will shut down in about 5 mins
First things first: "work" in giving this away has dodged the "responsible disposal" bullet. Drivers for this unit are probably limited to windows 98 or earlier, as the last Packard-Bell was produced in that era. Drivers for sound in particular were Packard-Bell only, and since they aren't around any more unless you can get your hands on the original installation CD you're out of luck to make the existing soundcard work. You do howrever have the option to install a newer soundcard, that should fix that issue. As for the shutting down, make sure the heatsink has good thermal contact with the processor as it sounds like the processor may be overheating. If there's a fan make sure it is running.
You've got a challenge if you want to see it all work, have fun.
Posted on May 31, 2009
Anonymous
  • 10319 Answers
SOURCE: where can i get free sound card for packard bell
http://www.google.com/search?q=sound+card+for+packard+bell+imedia+5070+&rls=com.microsoft:en-us:IE-ContextMenu&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GWYE_en
Posted on Jul 31, 2010
2helpful
I can get no sound from my computer atall. device "multimedia audio controller" has no driver, I am unsure which driver I need to install and where I can get it from - my computer is a packard...
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Packard bell itwin I have reloaded everything yet there is no No audio device or sound
you might have to get a portable usb sound card if you mean dont have a sound card installed or
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
1helpful
My packard bell note book sound like if is
check the sound effect first,...is it on "none" effect ? if yes try to resoldering the connection point on sound card by solder. good luck
1helpful
Plaese where can i download free drivers for my packard bell computer which i just finihed installing the operating system on.To be specific i need audio drivers and VGA drivers. Thank you.
Hi, if the audio, and VGA are not Packard Bell? part of the installation package that came with your product? Then you have to find the product name of each item. Sound Card (manufacturer’s name). VGA: type & model#. Search online by products / drivers. Thanks paul7of9
1helpful
Have dropped my laptop and the sound is intermittently slow and heavily distorted
You'll need to replace the motherboard, the computer does not have a separate sound card. Very expensive to fix unless you can do the work yourself.
Sound drivers
You will need to download your drivers from packard bell, select your country and enter the laptop serial number printed on service tag, then select download drivers and download and run the audio driver.
Here is the link:
Packard Bell Support
PACKARD BELL AND SAMSUNG TV
Many Packard-Bell systems use a Crystal sound card.
If you can read the number from the sound card (usually CSXXXX), you can pick the exact driver from this site:
http://drivers.myfreewares.com/vendordrivers-7-217-crystal-semiconductors-soundcard-download.html
Our Computer had a virus, someone put another version of windows XP on and then we lost everything including our sound.
If you can get the number from the card (usually CSXXXX) you can pick the right driver from this site:
Top Packard Bell Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
