Question about Belkin F1DL102P 2-port KVM Switch
I hooked up my belkin kvm switch f1dk102p it worked the first time and then nothing.it would not let me do anything. After removing the kvm switch,one of the computers has lost the use of my mouse and key board. I'm lost?. Thanks Greg.
    Problem Solver:
  • 14 Answers
Unplug all the cables and replug them in. This is a fine kvm switch and should work properly for all almost all configurations.
Posted on Feb 08, 2011
Hi how can i switch computers using Belkin
Try tapping the scroll lock key twice and then the up or down arrows, or tapping the scroll lock key twice and then the "s" key to auto scan.
Dec 05, 2009 | Belkin F1DK102P 2-port KVM Switch
I am using Vista and XP to run belkin peripheral switch for printing. The switch is not always seen by the OS. Is there a driver to fix?
ok- i use the same one, no driver needed- you hook it all up then boot the pc's and you hit the scroll lock key two times-then tap the up or down keys once. this will switch between the 2 pc's- this is a decent switch, and i really like it. good luck with it! if you need further assistance reply. but this is simple to make it work, so you should be ok. be well!
Oct 22, 2009 | Belkin F1DK102P 2-port KVM Switch
Switch stopped working
Have you tried tapping the Scroll Lock key twice and then 1 or 2 for each PC?
Apr 15, 2009 | Belkin F1DK102P 2-port KVM Switch
Kvm stopped working
Have you tried tapping the Scroll Lock key twice and then either 1 or 2 for each PC?
Belkin 2-port kvm switch
mcdevito75 here, You can try to contact Belkin itself, but with-in the 2 years you had wireless, many more users of different computers, and satalites that the wireless needs have also changed.
Jun 01, 2008 | Belkin F1DK102P 2-port KVM Switch
About the belkin 2 port kvm switch
i already have one computer hooked up to a beklin. can i hook up another
Apr 09, 2008 | Belkin F1DK102P 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin 2 port kvm toggling
What is the model name?
Press Scroll Lock two times within two seconds. Then press the Arrow keys, up or down to switch between ports. Or press Scroll Lock two times and the press the number One or Two key to switch between ports.
Nov 16, 2007 | Belkin F1DK102P 2-port KVM Switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin F1DL102P 2-port KVM Switch Logo
181 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
