Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Just got a dyson animal bagless upright. Put it together but the brushes are not turning..
Manchester Vacs
    Filmmaker:
    Uploaded 5 video answers.
  • 107 Answers
Look for the clutch knob as per the picture. Turn it one click to the right. The brushes will only turn when the machine is reclined; not when it is stood up.
Posted on Feb 13, 2011
DC17 Brush bar not spinning. Broken Belt. How do i replace it?
Put the belt on the motor shaft first, slide the brushroll through it. Put it all back together.
Jan 07, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal, purple ball, no suction upright
you might be missing a blockage in the hose from the brushes to the dust collector Take apart the hoses and check
Jul 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc 17 vacuum. brush not moving
The cog belt is probably not aligned with the motor gear. Watch this video and follow its instructions closely.
Apr 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I remove the part to reconnect the belt around the brush?
there are 4 screws on the base plate then slide out the brush then you can put the belt back on
Sep 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush on my Dyson DC17 Animal does not turn
Remove the plate over the brushbar. Gently clean out debris. Put plate back on,plug in and turn on vac and press brush bar button to reset.
Mar 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
In need of a picture of the on/off switch for Dyson DC17.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Feb 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC14 animal bagless upright
Make sure unit is on carpet setting. If is is chances are the belt connecting the clutch to the motor is broken.
Aug 03, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Motor loud
when you put the handle down it turns on the brush roll. you may need to clean the brush roll or replce it if the bearings are bad.also clutch and 2 belts are started when putting handle down for brush operation.
Jun 14, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
48 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Mike
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
