Sound driver for IBM is soundmax.
Go to the device manager, right click the sound devices, remove them. reboot and it should reinstall the drivers. could just be a odd conflict, the fix above should get it going again.
Or If you've installed the correct driver for your computer and OS and still no sound:Open Control Panel>Sound and Audio Devices>Audio tab>Sound Playback, Default Device, should something like Realtek...., AC97... If not the driver is not correct or the installation of the driver failed.
If the driver shows to be as described above. The issue is: Mute turned on, Volume too low, speakers not connected properly, no power to speakers , speakers not powered on.
I followed the instructions and SoundMax was reinstalled. Still no sound. When I went to the Sound and Audio Devices area, under Audio it says "No playback devices." It also says "No audio device" in the Volume tab.
You need to download new updated drivers from IBM site and still problem remains then you must rush to your system dealer or a authorized dealer.
