Minolta Dimage Scan Dual II Film Scanner Logo
A
Anonymous Posted on Feb 06, 2011
I am looking for a driver for the dimage scan dual ii that will work with windows 7
acacandy
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 06, 2011
acacandy
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
3603
Points
17
The drivers that came with the unit will work fine under Windows 7. If you get warning messages while installing them, just choose to ignore and continue.
1helpful
2answers
Using my Dimage Scan Dual 4 SW with Windows 7 gives me trouble. Have konica Minolta SW ver. 1.0.0 for windows XP. It works fine on the XP computer. But I have great difficulties loading the SW on
Have you right clicked on the .exe file of windows 7 executable for the Minolta scanner to select compatibility to switch it back to xp.Have you tried to use third party twain drivers for scan software such as silverfast or vuescan instead?
2answers
I have Windows Vista and cannot find the software on my computer to run my Minolta Dimage Scan Dual II scanner. How do I use it with my computer? Thank you Jane Young
Hi ,
Could be because there are no drivers running under Windows Seven for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
5helpful
2answers
Konica Minolta Dimage scan dual film scanner will not connect to windows 7
Copy this into a text file named "sonyscanners.inf" and then manually point to it as the correct driver in device manager for your scanner and it'll all work like magic again. Forget using a virtual machine...not needed. I use this for both the Dimage IV and 5400 Elite in Windows 7 64-Bit.
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
10helpful
Need drivers for Minolta Dimage Scan Dual III to work with Windows 7 64-bits
I used this solution from KainAnderson
1) Install the Konica Minolta XP software in Win 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It may detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Class=Image
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
[Models]
; USB scanners
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c:\newminolta\newminolta.inf)
6. Go to control panel (View Devices and Printers).
7. Right click on Minolta Scan Dual III and click on properties.8. Select Hardware tab, then select Properties
9. Select Driver tab, then select update driver
10. Select Browse my computer for driver software.
11. Browse to c:\newminolta\newminolta.inf (or wherever you stored file) and click Next
12. Click Next. After running driver file Win 7 should now say it updated driver.
13. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
14 Open door and insert film holder and start scanning.
Hopefully I've copied and amended the solution correctly
17helpful
4answers
I am attempting to use my Dimage Scan Dual 4, with windows 7, but I receive an error 4 message, stating that the scanner connection cannot be confirmed. Any ideas? Ron
1) Install the Konica Minolta XP software in Vista/Windows 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USBVid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USBVid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USBVid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USBVid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USBVid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USBVid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USBVid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USBVid_0638&Pid_0a16
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: newminolta newminolta.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta Scan Dual IV and click on driver tab. Select Update Driver.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c:\newminolta newminolta.inf and click OK
14. Click Next. Vista should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
Software upgrade?
It works fine on XP, I am using it with XP SP3 currently. You should download the current driver from Minolta. Install the software before hooking up the scanner. I prefer to remove any existing drivers and re-boot before installing new drivers.
4helpful
2answers
Konica Minolta Dimage Dual IV
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: ewminolta ewminolta.inf)
13. Browse to c: ewminolta ewminolta.inf and click OK
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
