Question about Panasonic KX-TG1033S Cordless Phone
When I press Talk one of my handsets says "No link to base. Move closer to base, try again.", even when I am sitting right next to the base. I cannot connect with the other handsets either - it reads "Busy" when I press Talk. I tried changing the batteries, this didn't help.
Posted by shelleybr515 on
thuan_tha6
    New Friend:
NO LIN TO BASE MOVE CLOSER TO BASE, TRY AGAIN
Posted on Feb 14, 2011
Joe A
    New Friend:
  • 3 Answers
IMPORTANT: You need to DEREGISTER the new handset by using one of the OLD ACTIVE handsets. Note the handset number (1, 2, 3, or??) on the new phone - it is on the screen. Then go through the deregistration process described in the manual using one of the working handsets. At the last step it will ask you to input the number of the handset to be deregistered. After you type that number in, the new handset will be ready to accept registeration to your handset. Now go through that procedure using the NEW handset and it willwork.
Posted on Nov 10, 2015
What does "No link to base, move closer to base, try again"
Always use the Handset, (handset 1) that sits on the base and check in your manual, on how far the reception goes. As there is a limit.
Jul 01, 2014 | Uniden Cordless Phone
The telephone batteries are fully charged; however when I attempt to use the telephone I receive a message stating, "No link to base. Move closer to base, try again." The telephone is very close...
Check your user's manual for registration, or RE-REGISTER the handset to the base. In essence, it involves stepping to the registration on the handset, pushing the handset locator button on the base, then saying OK on the handset. They will sync up.
Carl
Feb 10, 2011 | Panasonic Lands Phones
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
When the Talk button is depressed on one of our two handsets the screen reads: "No link to base. Move closer to base and try again." The other handsets performs as it always has.
Hi Jim.
About the problem with the answer received, you should write to [email protected] They usually reply within next working day.
About the system, if you have not sent the system for repair yet, you should do a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wallsockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective.
I wanted to remind that the feedback given to the expert does not afftect refund procedure, and do not affect your status. In some case I get negative feedback while trying to help dissatisfied
askers in troubles with Fixya service. That is not really nice and pleasant. :)
All the best.
Ginko.
Jan 10, 2011 | Panasonic GigaRange KX-TG5240M Cordless...
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
1,229 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
