Palm Zire 21 Handheld Logo
Question about Palm Zire 21 Handheld
My Zire 21 ran out of battery and I plugged to charge it. After that all my data was gone!!! Is there a way to get it back?
Posted by jcbarbano on
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: lost data on palm zire 21 hand held
To the best of my knowledge, if you don't have a pc backup, you are out of luck.... Sorry to be the bearer of bad news... Download the Palm Desktop Software and start to use it if you decide to continue using the Zire 21. The Software is free from Palm.
Posted on Sep 26, 2007
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: palm Zire to itouch
Those two devices are not compatible to one another. You may get it to work by exporting the Palm desktop data into a CSV file and importing it into the program you use to sync the Itouch with.
Posted on Jun 09, 2008
ctau
castletech
  • 372 Answers
SOURCE: the information on my Palm Zire 71 all appears to have been lost.
looks like it's completely gone, hope you kept backups.
was the data stored on the SD-Card, if so try putting the sd-card in a computer/card reader.
Posted on Mar 20, 2009
Anonymous
  • 3278 Answers
SOURCE: how do i fix a zire 21 palm it wont turn on,
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Posted on Nov 03, 2009
Anonymous
SOURCE: My PalmOne Zire 72S battery won't charge. How do I
I can't get the back off my 72s to replace the battery, any instructions would be appreciated. One source says there is a third screw in the wire mesh but I only found the 2 lower ones. Also, I can't find the Media Icon anywhere, therefore I can't use the camera or download pics. I even reloaded the software to no avail.
Posted on Feb 09, 2010
Lost contacts on my Palm Zire 31
No, only if you synchronized with another device beforehand. Using Palm Desktop, eg, you could synchronize and get the list back.
Dropped Zire21 and lost all data, how can i retreive the data.
Please check all loose wiring connection inside your Zire and get it fixed.
1helpful
My Plam Zire 21 handheld has worked fine; suddenly it will not turn on, or at least the screen remains dark. I have tried re-charging the battery, and resetting the device, but to no avail. Any other...
It is possible that the battery has lost it's skill. If you can plug it in, either by usb to a computer or through the power supply, and the screen shows it is a goner.
The link below is for the palm zire m150 if your interested in replacing the battery yourself. The zire 21 is similar to that model so it's pretty much universal.
http://www.directfix.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=GHT&Category_Code=_ZIRETAKE
1helpful
1helpful
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
handheld.
longer.)
b. Tap Home .
Hope this helps.
1helpful
2answers
The touch screen of my zire 21 does not react to the stylus.
Digitizer is out. Take it to a cell phone repair store but be prepared to pay out the nose. In essence, back it up and throw it.
The information on my Palm Zire 71 all appears to have been lost.
Lost data on palm zire 21 hand held
3helpful
4answers
PDA is totally black; not charging
The easiest solutions are easily overlooked. 1. Check your charger; a cheap multimeter will do for the voltage check. If the voltage (dc) written on the back of the charger is what you get at the plug, go to (2),if not, change your charger,problem solved. 2.You either have a messed up screen or battery. 3. Check the voltage at your battery terminals after charging the battery for like 1hr. If you do not get a resonable read; 2-5v ,just trash the battery and head for the nearest shop to get a fresh one.In case your battery reads okay,your screen or worse, one of the components on the board of the set has gone kaput.
Top Palm Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
