Typically its a problem with the disc tray, a variety of solutions can be gently tapping on the top of the xbox immediately after the disc tray closes. Another suggestion is, and don't do this very often, but when the disc tray closes, immediately turn your xbox 90 degrees backwards so the Disc tray is facing up at the ceiling. If these fail, you may simply just have to play with the disc tray, grab it while closing, dont tug too much, slam it closed really fast. Microsoft really is **** when it comes to making things last, but these should work somewhat, you might just have to buy a new xbox if they don't ever work.
Follow this method and it will work for you.Turn on your console while holding down the "A" button with no game in
the tray will eventually open just dont let off the "A" button when it
does open then let off the "A" button and insert ur game and close ur
disc tray.
this is a problem the microsoft has been working on ... remove any disc from the tray> unplug it from all power the plug it back in> open the disc tray .. leave it open for a little while like 10-15 seconds .. then put the game in and it should work .. if it does not however you have one of the defected disc trays and you'll need to get it repaired by microsoft .. i know its not what you want to hear but hey at least they will fix it free of charge =]
take it to get a new drive (make sure they replace it)
unless you have a warrantee for the product i would would sent it back to MICROSOFT for a replacement you should have one year warrantee.
Call microsoft Xbox360 dept. or check their website.
This is an indication that the optics are either dirty or failing. Carefully open up the unit and clean the lens using a cotton swab and alcohol. That should resolve the problem. If not, try playing a music CD. If the CD plays but a DVD does not, the optics are failing and need to be replaced.
Dan
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the
disc tray with the label facing up (to the right if the console is
vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will
append all tracks on your current CD to that playlist. Selecting Play
All will clear a current playlist and create a new one consisting of
all the files on the current CD. (Be sure to save your playlist, if
desired, prior to selecting the Play All option.) Files are added to a
playlist in alphabetical order by file name. Playlists start again from
the beginning once the final track has played.
Try opening the disk tray with the 360 off.
Push a paper clip into 1 of these holes in your 360. It will pop the tray out. Grab the tray pull it out all the way. Put a game in, leave it open! Then turn your 360 on see if it boots the game.
"Your Disk tray might be going bad. It might be fixable but I will have to try it out on a bad drive which iI dont have at this time."
