Cfm Daikin R410a Split System Air Conditioner Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air conditioner goes on for about ten minutes then shorts the electric circuit it is connected to.
Thomas Woodburn
Level 3:
  • Cfm Master 2,638 Answers
  • Posted on Jun 12, 2018
Thomas Woodburn
Cfm Master
Level 3:
Answers
2638
Questions
Helped
1250609
Points
7008
Sounds like an over amping issue. start by making sure everything is clean. then, with a little experience and power off. make sure all electrical connections are tight.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Betty Bloom
Level 2:
New Friend:
  • Expert 20 Answers
Betty Bloom
Expert
Level 2:
New Friend:
Answers
20
Questions
0
Helped
36712
Points
113
I also have Daikin air conditioning, but there were no similar problems with it. Have you cleaned your air conditioner filters? If so, then the problem is more serious and you should definitely study the list of Daikin air troubleshooting. Daikin air troubleshooting
Anonymous
Level 3:
  • Cfm Master 43,501 Answers
  • Posted on Feb 06, 2011
Anonymous
Cfm Master
Level 3:
Answers
43501
Questions
0
Helped
10834904
Points
101584
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
1helpful
2answers
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Overheat protection tripping
Starts running and after about ten minutes trips the circuit breaker anf nthe shuts off. This is the PLM14000EH.
1helpful
Just bought a 2006 used RV and the air conditioner was working when I bought it and worked at home on a generator but just went to a camp site and hooked up and it will not work at all. Maintance at the...
I have never seen a fuss or circuit breaker in the ceiling of a RV. turn power off or unplug the RV and check all electrical connections to the air conditioner. It may be a lose connection.
Air condit. runs for ten minutes , shuts off and displays E1
You should first look in the instruction/operation manual usually in the back pages for trouble shooting or code faults (errors). There should be a list of faults such as E1, E2, E33, E44 etc. and an explanation of each code. If you cannot find this info, call the manufacture ; they will tell you exactly what the E1 fault code stands for and possibly what will correct it. Ask for technical support. The fact that it runs for 10 minutes and stops; if you unplug it or turn the control to off, will it start again when you reenergize it ? This could indicate low voltage from the electric source. Are you running it with an extention cord or is the electric circuit line a very long run and robbing power before it gets to the unit? Have you checked the filter so that it is clean enough for good air flow, otherwise the unit will detect the low air movement from a dirty filter and shut itself down.
Display shows p2 on aircon
1、Check whether the resistance of the sensor is
normal (the resistance is 5Кω in the normal
temperature 25℃), when it is abnormal the sensor
should be replaced.
2、Check whether there is short circuit or open circuit
in the wire of the sensor, and whether the plug is
connected well, whether there is welding off or
rosin joint on the electric control board, if there is
any, it should be repaired.
3、When the 1 and 2 are both normal, then the
components or integrated circuit is damaged, the
electric control board should be replaced.
1helpful
2answers
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
2answers
Dometic RV Rooftop A/C stopped working. Burnt electrical smell
if you can find a decent a/c mn in the area he might be able to patch you up until you get to an authorized dealer?
Top Cfm Heating & Cooling Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
