Question about Frigidaire FAD704TDD Dehumidifier
Dehumidifier is running and the filter is clean but it hasn't collected water in a couple weeks. It is in the basement, which is very moist, so I know there IS water to collect!!
Posted by srw462 on
D. Floyd Kolb
  • Frigidaire Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
0-
Posted on Mar 07, 2011
Clean cooling coils. in the last week or so my dehumidifer in the basement seems less productive in collecting water, i have two down there and the other works - i have to empty it often, thats how i...
heatman101
Sep 18, 2011 | Maytag M7DH45B2A Dehumidifier
My Dehumidifier goes on for 3 minutes & shuts off. Cleaned filter, adjusted humidity settings, & moved unit to different areas of basement.
heatman101
Aug 05, 2011 | Dehumidifiers
Front has moisture on fins, runs but does not take out much water even though basement is real wet, I noted the whole front was frozen last week...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 14, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
The unit turns on and appears to work, but no water is collected
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Jun 02, 2010 | Haier HD306 Dehumidifier
It is not collecting water.
heatman101
May 18, 2010 | Fedders R6DH45X Dehumidifier
My dehumidifier is about a year old. Plugged it in and it ran for 6 hours but no water in bucket. Cleaned the air filter and no moisture taken from a very damp basement
heatman101
Jun 24, 2009 | Danby DDR401 Dehumidifier
Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 05, 2008 | Haier HDN655E Dehumidifier
Kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Jul 31, 2008 | Dehumidifiers
Everything works, but does not collect water
I have the same dehumidifer - make and model. I bought it less than a year ago. It too runs fine, but now collects no water. Did you ever discover how to fix the problem?
Sep 04, 2006 | Goldstar DH504EL Dehumidifier
Frigidaire FAD704TDD Dehumidifier Logo
796 people viewed this question
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Andrew Taylor
Andrew Taylor
STEVE SPAM REMOVER
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
