Question about Yard Machines Garden
My ride on runs well for about half an hour or less then starts to lose power then stall will restart and then stall again in a few minutes
Posted by johnotoole_6 on
Gary Nigro
  • 927 Answers
Try loosening the gas cap just as it begins to lose power. If this clears the problem, clear the vent holes in the cap.
Gary
Posted on Feb 06, 2011
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
Ford excursion 2002 - starting fine but losing power and stalling after running for 10 minutes. Rest for about 5 minutes, then starts up again
Can you perform a spark test? I would like to know if it has spark when it stalls. Also, if you have a can of starter fluid, wait for it to stall and not want to restart, the quickly spray some starter fluid into the intake. If it runs on the starter fluid, you have a fuel issue. You might also want to make sure the engine coolant level is fine and you aren't overheating. If you coolant level is low you may not know it is overheating since the coolant sensor isn't in coolant. It won't read air.
Jan 28, 2014 | Ford Excursion Cars & Trucks
1995 Buick Century. Engine stalls after ~5 minutes when started warm. Engine runs rough for a few seconds before stalling. Happens even at highway cruising speed. Will crank and fire and stall when you...
Using excessive fuel cleaner can damage injectors and the fuel pump - sounds like your problem is the fuel pump bearings, and you will probably have to have it replaced.
Jun 13, 2017 | Buick Century Cars & Trucks
Engine stalling
I also have 1996 Maxima SE and had same problem. After several months of searching and asking around, I was able to fix the problem by replacing the Mass Air Flow sensor. I replaced with aftermarket MAF and paid $80 with lifetime warranty and the car runs better with better gas milage.
To replace the part takes less than 30 mins., I would recommend replacing the part as maintenance. Otherwise, you can take it to a mechanic and they may spend hours trying to troubleshoot your problem. During my research, there are so many different things that could cause the car to stall and ride rough. I am NOT a mechanic and take my advice for what it is worth and replace the part. It will be less expense if it fixes the problem otherwise you'll need to take to mechanic. They will charge you at least $400 to $500 for an half-hour job.
Good luck. I know how frustrating it can be with repairing the car cost more than it is cost.
Aug 13, 2012 | 1996 Nissan Maxima
My Vespa PX125 Disc loses power on the journey.
adjust air mixture screw at rear of carb tighten it first then loosen it 1& half turns give it a go
Apr 17, 2010 | Peg Perego Vespa Scooter
1989 Jaguar Vanden Plas. Stalling on longer journeys
Fuel pump...change the fuel filter at the same time....
Sep 30, 2009 | 1989 Jaguar Vanden Plas
Engine stalls and won't restart for several minutes
I parked the car out behind the wood shed and in 15 to 20 years the car will be a classic.Then I'll give it to one of my grandchildren (if I have any) and let them figure it out.
Dec 03, 2008 | 1996 Oldsmobile Eighty Eight
Garden Logo
212 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
john h
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
