Question about Philips GoGear SA178 MP3 Player
Can't install on newer laptop, as it requires Windows XP, and my new laptop has Windows 7. Do you have a driver I can install to communicate with it?
Posted by kyboyinfla on
Chintu-KPV
    Novelist:
    Champion:
  • 202 Answers
1. With Win7, most of the drivers come with / through OS itself.
visit this page for more details on how to update the drivers.
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
2. Also, what I see from the site is that musicmatch jukebox is useful to put songs in there.
3. By default, the windows media player recognises the device you plug in automatically (Try changing the device access mode of your player to MTP and then plug it in)
4. Your player can automatically recognise the songs (so, you can plug it in USB storage mode also and try syncing with the windows media player 12 - click the sync tab on the window)
5. You may need the latest firmware for your device (CAUTION: update it only after reading the manual carefully, otherwise it may get unusable)
Here are some links for the softwares (from the philips site)
1. CD contents: http://download.p4c.philips.com/files/s/sa178_17/sa178_17_cdi_aen.zip
2. Musicmatch juke box (may be obsolete): http://download.p4c.philips.com/files/s/sa178_17/sa178_17_mjs_aen.exe
3. Frimware upgrade:
3.1 Readme:http://download.p4c.philips.com/files/s/sa178_17/sa178_17_fur_aen.htm
3.2 firmware: http://download.p4c.philips.com/files/s/sa178_17/sa178_17_fus_aen.zip
Good Luck
Posted on Feb 06, 2011
Genius G-Pen 560 Tablet Driver won't Install on Windows 7
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet.
Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
Apr 03, 2012 | Genius G-Pen 560, USB 4.5 x 6 tablet with...
My LG X200 works with Windows 7. Can I install XP on this model. And if I install XP, the drivers available for windows 7 will work on XP?
The drivers for Wndows 7 most likely will not work on Windows XP.
If this laptop came installed with Windows 7 it may not have Windows XP drivers.
Before you install Windows XP check the LG WEB site for Windows XP drivers for your model laptop. If there isn't any XP drivers then I suggest you stick with Windows 7.
May 20, 2011 | Computers & Internet
I use a D-Link DWL-G122 USB Wireless adapter on my laptop, but I recently upgraded to Windows 7 and now the driver which was more for Win XP doesn't work very well. Is there a newer driver that is for Win...
you can try to see if there is a Windows & driver for your Air Plus adapter at the D-Link site if not use the windows compatibility feature to load the drivers for you device.
2. you can also use this feature :
Install and use Windows XP Mode in Windows 73.check the windows "help and support" link under the Orb in Windows 7 to get full instruction set to install and use Windows xp mode in Windows 7.
Apr 24, 2011 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
Google chrome requires windows xp
The installation of Google chrome requires Windows XP Service Pack 2 or newer OS.
It seems, that your system doesn't fullfill this requirement.
Feb 23, 2011 | Google Chrome
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Install windows xp in compaq presario cq45
There is no drivers for Windows XP for this notebook, only Vista and Windows 7. My advice is to install Windows 7 - it works just fine.
Oct 21, 2010 | Compaq Presario Notebook
No drivers
If the operating system on the laptop is pre windows xp - in other words windows 2000, windows 98, windows 95 you will have to manually go to each manuf of the device you need drivers for and most companies will have a location on there website that allows you to download what you need.If it is windows xp or newer such as windows vista or windows 7.the operating system is much more user friendly and driver installation problems become virtually eliminated.
Aug 30, 2010 | Computers & Internet
Does Go To Meeting work with Windows 7?
Here are the system requirements:
or PC-based Organizers and Attendees
  • Required: Windows® 7, Vista, XP, 2003 Server or 2000 (Linux is not supported)
  • Required: Internet Explorer® 6.0 or newer, or Mozilla® Firefox® 3.0 or newer (JavaScript™ and Java™ enabled) . If needed, download Java here.
  • Internet Connection Required: Cable modem, DSL, or better recommended
  • Recommended: Minimum of Pentium® class 1GHz CPU with 512 MB of RAM (2 GB of RAM for Windows Vista)
May 15, 2010 | Citrix GoToMeeting
I want to install Windows 7 on my laptop, it fulfills all the requirements but i want to know tht if Windows 7 drivers for Samsung X05 are available on any site or Windows Vista/Win XP Drivers supports...
If you are updating from Winos XP orsome higher version to Windows 7, an automatic update is run which backup allthe data, installed files and saved application settings.If you freshly install Windows 7 inyour PC, it will remove all the installed applications and saved settings.
Jan 11, 2010 | Samsung X05 Notebook
Philips GoGear SA178 MP3 Player Logo
138 people viewed this question
Top Philips Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
aliasger yq
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
