Well you will need to use a pipe wrench and yes it will mess up the nipple. You will need to buy a new nipple and install it after the tube has been replaced. If you have can get a inside the pipe nipple extractor tool you can remove it (most of the time) unharmed.
It sounds like you a replacement tube that comes with nipple built in, if that the case your good to go without a new nipple.
1) Rheem power vent series:
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
2) Looking at product over-view manual: It says 'inlet connects directly to a dip tube which directs water to bottom of the tank.'
So it appears that dip tub is connected to heat trap nipple on cold water side
3) Sample manual for Rheem shows exploded parts list
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
The exploded view shows cold water nipple separate from dip tube, and shows dip tube gasket, and makes it unclear
4) Manual shows Rheem phone number:
1-800-432-8373
5) You can also post specific questions like this on pro water heater forum: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. As general rule, expert will not answer unless they know specific answer, to avoid dissatisfied customer.
Fixya is always less expensive than a service call.
