Question about Haier HVT12ABS Compact Wine Cooler
Haier hvt12a does not cool The inside and outside fan work Any Ideas
Posted by Allen rench on
1 Related Answer
mark92230
  • 413 Answers
SOURCE: Haier HR30A1var fan outside is
If you have fuses outside, check or change them..Also check the circuit breakers in your circuit box.
Posted on Apr 11, 2011
My Haier compact refrigerator suddenly stopped cooling.i cleared ice buildup and returned power to it .waited 30 minutes and still not cooling.what can I check
Check if the compressor fan motor is engaging. If the fan is not spinning then the coil will freeze up again. Also check that there is enough air movement around the fan for circulation. This is also try for the inside fan. Good luck
Dec 13, 2016 | Haier Refrigerators
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
Hi it sounds like LOTs of water running in the unit. I looked in and there is LOTS or water in the bottom of the unit Is this OK ??
Yes, the a/c unit removesmoisture from the air inside the home and allows it to drain to the outside of the unit, once there the water sits in the outside of the unit and the outside fan blade has a ring on it known as a slinger ring wwhich picks up and throws water on the outside coil cooling it to inprove cooling and efficiancy.
Jul 22, 2011 | Haier Heating & Cooling
Haier HR30A1var fan outside is not turning and blowing hot air inside
Apr 11, 2011 | Haier HC48C1VAR Central Air Conditioner
When I start my ac it works unless it's working really hard for a long period. In this case it runs but stops cooling. Any ideas on what the problem could be?
I would make sure that the outside coil (condenser) is clean. It sounds as if it overloads on hot days. Make sure the inside filter is clean. too.
Jun 14, 2009 | Haier Energy Star ESA3183 Air Conditioner
Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
May 26, 2009 | Heating & Cooling
Haier AC HWR10xc6
Haier Air Conditioners do not have a drain hole or hose like most A/Cs. This problem can easily be solved by carefully drililng about an 1/8 or 1/4 inch hole in the bottom outside edge directly on the metal frame, around the cooling fins.... This will elt the water drain out...if you when outside and looked in while it was spitting you would see the water pooling up in there. Haier expects us to mount these units at an ungodly angle to drain the water, but drilling a small hole will help (really anywhere in that bottom plate would work since the whole bottom is a "drain pan"
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
My AC not working
Hi again,
The electrical supply needs checking in the outside unit.
Start at any supply fuses, and work around to the compressor.
If it is getting a supply out there, then it is a control issue. There should be a thermostat or controller that will turn the outside unit on if cooling is required. This is the defective part, as the signal to start is not getting there.
Check the outputs from the thermostat on the inside - one contact should close to turn the outside unit on.
Hope this helps. If it enables you to fix it please take a moment to rate this as fixya!
If not, I'll go on further
Thanks.
Jun 16, 2008 | Haier HPAC99ER Air Conditioner
Haier HVT12ABS Compact Wine Cooler Logo
109 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
