Question about Saitek X52 Flight Control System
I bought a new X52 Flight control system. After installing it, the throttle works fine but the Joystick doesn't work (altough the LEDs are on). I download the drivers from SAITEK website but it still does not work. I have a Windows Vista 32-bit PC.
Posted by rricardomadr on
  • 1 more comment
  • rricardomadr Feb 06, 2011
    I followed your instructions (go to control panel-joystick properties), but there is not a Calibration buttons or option as you can see at the picture included.
    In the Saitek X52 Flight Stick Properties Windows, pressing Throttle buttons and movements are shown OK in the screen, but pressing Joystick buttons and movements are not shown in the screen. All the joystick LEDs are on, but the Joystick actions do not work at all.
    I tried that in a Windows Vista Home PC and also in a Windows XP Pro PC, but in both of them I got the same behavior.
    I also tried restarting the PC, reinstalling the drivers and updating the drivers from Saitek web page.
  • rricardomadr Feb 07, 2011
    The d3drm.dll file was there in c:\windows\system32. Anyway I downloaded and put i there again. Reinstalled drivers but the problem was not fixed and the joystick continues without working at all.
    Actually it's the same link you mentioned in the previous posting.
Anonymous
    Genius:
  • 1,400 Answers
Hello
Go to control panel.devices and printers.Find your joystick.right click on the icon then select game controller settings.then properties then settings then calibrate.
Once at calibrate follow the instructions on how to calibrate.
Also you may want to try shutting down your pc.Unplug your joystick.Restart the pc,once started plug your joystick back in, and let windows reinstall it.
Hope this helps
Thanks for using Fix ya
Posted on Feb 06, 2011
X52 pro mouse function
How to bring up other e-mail that not opened a while: [email protected] ?
1helpful
2answers
I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
3helpful
My saitek x52 joystick wont work. Flashing lights every half second. Throttle works fine.
My X52 began doing this after hundreds of hours of use. Joystick lights flashing twice per second. Throttle operative but joystick (and buttons) not.
The problem was 2 wires inside the joystick base that had eventually been sawed in half by the sharp edge of the metal tube that carries the wires up into the stick. I have no doubt that this same issue could cause intermittent operation if just the insulation is worn off of more than one wire.
The fix: Remove the 4 screws from the base and lift the joystick assy out of the base. Inspect the wires where they emerge from the metal tube. You will find wires broken, or, insulation rubbed off. If you have broken wires, strip the ends and solder them together...you should have about 1/4 inch of "slop" up in the top end so you can pull the top wires down enough to strip and solder. If you re-insulate the solder splices with heat shrink or spaghetti tubing I would keep the amount used minimal...these wires need to remain somewhat flexible when the stick is being used.
Finally, I fixed the engineering defect that caused this in the first place by immobilizing the wire bundle with hot glue at the tube opening to prevent future contact with the sharp tube end. If your only problem was skinned insulation, this hot glue application may be all you need to do to keep the exposed conductors from contacting each other or the tube.
Speaking of "slop", you will also be contending with a bunch of silicone grease that lubricates the wire and mechanism.
1helpful
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
1helpful
2answers
My joystick will not respond.
you have to plug the round tipped courd into the slot in both controllers, connecting both. you only plug one thing into your computer and that is the usb cord built into the throttle control.
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
2answers
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Saitek X52 Flight Control System Logo
Top Saitek Video Game Consoles & Games Experts
Ekse
 TE5LA
TE5LA
ADMIN Canada
ADMIN Canada
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
