Dell Latitude / Inspiron CD-CDRW/DVD Combo Drive. (8F947-A00) CD-ROM Drive Logo
John Redmond Posted on Feb 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a driver for 8 x cd-rw/dvd 8f947-a00 - Dell Latitude / Inspiron CD-CDRW/DVD Combo Drive. (8F947-A00) CD-ROM Drive
Anonymous
Level 3:
Genius:
  • Master 1,189 Answers
  • Posted on Feb 05, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1189
Questions
0
Helped
360597
Points
3265
In my desktop computer the LG CD/DVD writer/reader is showing empty though the CD is filled with data..hat could be the reason, i tried by re-installing the drivers but no success...
Not knowing the operating system, In windows 7 and 8 sometimes it forgets the cd format. Then you need to go to the device manager and remove the drive and let windows re-detect it.
Cd drive is not working
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
The drive is detected but it does not appear to read cds or dvds inserted. I can hear the drive spinning.
try this http://www.fixya.com/support/r3779147-restore_acer_portable_original_factory
if no go, see if you can boot to the drive using an Windows CD or the Dell resource CD, if it will not read or boot, Boot to BIOS, ensure it is identified there and try again, if still no go, then replace the drive
1helpful
I have a dell dimension 2200 that has a CD RW . I would like to replace it with a DVD RW or DVD CD RW. Is there going to be a problem with doing that? I have already replaced the CD RW years ago so I know...
You shouldn't have any problems upgrading to a DVD RW or DVD/CD RW as long as you make sure that you have all the drivers needed. The drive will probably have a disc containing all the drivers required, but in case it doesn't, simply visit the manufacturers website and they should have a driver download there :)
Don't forget to rate me if this helps :)
4helpful
Sony CD-RW CRX320EE driver update
CD-Rom and DVD drives in itself do not need drivers in Windows, but the IDE/SATA controllers they are connected to do, so maybe that is what you are looking for?
You can use a driver update program or check the website of your motherboard manufacturer.
4helpful
Can the hl-dt-st dvdram gsa-h40n record dual layer?
Yes it can, here are the specifications : -
Specifications of LG GSA-H40N write speed
CDR 48 x CDRW 32 x DVD-R 16 x DVD-RW 6 x DVD-R DL 8 x DVD+R 16 x DVD+RW 8 x DVD+R DL 8 x DVD-RAM 5 x read speed
CD 48 x DVD 16 x
DVD_RW ND-3550A 5XIFA95S211
HELLO THERE
here is a link that will help you out ok?
pease dont forget to give this solution a rating i really need it.
best regards mike
  1. Asus Cd-Rw & DVD-Rw Drivers You can download Asus Cd-Rw & DVD-Rw Drivers for your hardware. If you want to use Asus Cd-Rw & DVD-Rw Drivers for other purpose, Please contact ...
    www.updrivers.com/drivers/Cd-Rw_DVD-Rw/Asus/3/58.html - 9k - Cached
2answers
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
