Question about iRiver Story
Iriver cover story. All locked up, can't turn off, can't turn page, can't do anything. Can't read instruction manual as that is on iriver. Doesn;t respond to anything - help.
Anonymous
    New Friend:
Press on /off switch and home toggle together for about 6 seconds iriver should then reboot
Posted on Feb 20, 2011
  • Anonymous Feb 20, 2011
    Hold the on/off swithch together with the home toggle for at least 6 seconds - iriver should then reboot
Bert Bursch
    New Friend:
The "home toggle" is the "Back"-key. Don' forget to connect the USB-cable to avoid problems with the battery.Stay patient because after restart the "designed by iRiver"-page is shown for about 60 secs!Generally this a great solution! Thank you!
Posted on Apr 01, 2012
tip
Iriver Story HD vs Kindle
<br /> <a></a> <span><span><span>The Kindle 3 was released by Amazon in 2010. It is available in two colors, graphite or white. iriver Story HD becomes first Google eBooks-integrated e-reader, developed by Google and iriver, which is similar to Kindle, but the buttons are copper-colored. Here we compared iriver Story HD vs Kindle from multiple specs.</span></span></span> <br /> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Supported Formats</span></span></span> <span><span><span>Kindle supports eBook formats: AZW, TXT, MOBI and PRC.</span></span></span> <span><span><span>iriver Story HD supports: PDF, EPUB, TXT, DOC, PPT, XLS, HWP, DJVU,GB2.</span></span></span> <span><span><span>Note: sometimes conversion is need between different formats, </span></span></span><a href="http://www.drm-remove.com/resource/free-drm-remover.html"><span><span><span><span>drm free</span></span></span></span></a><span><span><span> is needed also. </span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>So according to the differences between iriver Story HD and Kindle,did you make a decision to buy which? </span></span></span> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Physical Features</span></span></span> <span><span><span>The Kindle 3 weighs 8.7 ounces, and is 7.5 by 4.8 by 0.3 inches in. It has a 6-inch screen with 600 by 800 pixel resolution using Pearl E Inktechnology. It uses 4 GB of flash memory for storage.</span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>The new iRiver eReader also boast a 6 inch XGA E Ink display with768&times;1024 pixels of resolution for a readable experience, 2GB of internalmemory, a 38 QWERTY keyboard with way controller for easy searching, USB 2.0port, wiFi and Lithium Polymer 1800 mAH battery provide read up to 140.000pages. In term of , the Google iRiver Story HD eReader measure in 128 x 9 x204 mm with weight 207 grams. (Related: </span></span></span><a href="http://www.drm-remove.com/resource/kindle-drm-remover.html"><span><span><span><span>remove kindle drm</span></span></span></span></a><span><span><span> , </span></span></span><a href="http://www.drm-remove.com/resource/remove-nook-drm-removal.html"><span><span><span><span>remove nook drm</span></span></span></span></a><span><span><span> )</span></span></span> <span></span> <span></span> <span><span><span>iriver Story HD vs Kindle: Display</span></span></span> <span><span><span>As you can see, whilst the devices look virtually identical in and shape, there is a slight difference in the actual displayed picture. Therepresentative that brought the piece of hardware also said that this iriverStory HD device will be the fastest refreshing e-reader on in the market currently.</span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Price</span></span></span> <span><span><span>The iriver Story HD will cost $139, which is the same price as theKindle or the Nook.</span></span></span> <span><span></span></span> <span><span><span><span><br /></span></span></span></span> <span><span><span>iriver Story HD vs Kindle: Connection</span></span></span> <span><span><span>The Kindle 3 can be connected to your computer using its USB datacable or using WiFi through your home network. For purchasing books fromAmazon, the Kindle 3 uses the same 3G wireless networks. It takes less than aminute to download a book using 3G Wireless, with no cost to the user forwireless access. (related software: </span></span></span><a href="http://www.drm-remove.com/resource/remove-drm-from-ebook.html"><span><span><span><span>drm ebook removal</span></span></span></span></a><span><span><span> )</span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>There's also WiFi - along with Easy Wi-Fi Network support for easierlogins at open hotspots, which means you can buy Google eBooks over Wi-Fi. </span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Supported Formats</span></span></span> <span><span><span>Kindle supports eBook formats: AZW, TXT, MOBI and PRC.</span></span></span> <span><span><span>iriver Story HD supports: PDF, EPUB, TXT, DOC, PPT, XLS, HWP, DJVU,GB2.</span></span></span> <span><span><span>Note: sometimes conversion is need between different formats, </span></span></span><a href="http://www.drm-remove.com/resource/free-drm-remover.html"><span><span><span><span>drm free</span></span></span></span></a><span><span><span> is needed also. </span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>So according to the differences between iriver Story HD and Kindle,did you make a decision to buy which? </span></span></span>
on Aug 01, 2011 • Computers & Internet
1helpful
I've downloaded books on to my e-reader but I can't read them because the font is tiny - unreadable. How do I change the font?
You can zoom text (txt) files but not pdf files. Try using this link:http://www.mobileread.mobi/forums/showthread.php?t=65652&page=2
the Iriver has a default font with 3 levels of zooms.
2helpful
I need a copy of how to use my iriver story. there was no manual in the package
You can download and print the instruction manual in PDF format by clicking this link. (This is a .zip file. After the download finishes, extract the file to view the manual)
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Where can i down load a user manual
for iriver story (Wi-Fi or Not Wi-Fi):
http://www.iriver.com/support/download_view.asp?SelectPart=All&FindWord=&product_name=002&model_name=&category=03&dNum=1019&page=1
Printable instruction booklet
You can download and print the instruction manual in PDF format by clicking this link:
http://www.iriver.com/support/download_view.asp?dNum=1019
Iriver H10 20GB
Simple reset should do the trick - remove and reinsert the battery.
If the problem persists, check the iRiver website for a firmware upgrade - their site is not the most user-friendly but it is CHOCK FULL of information.
Here's the link to the manual:
http://www.iriver.com/support/down_view.asp?searchProductIdx=61&searchCategoryIdx=2&searchString=&page=1&idx=710&tmpSearchProductIdx=&tmpSearchCategoryIdx=&tmpSearchString=
iRiver Story Logo
Top iRiver Computers & Internet Experts
Ekse
Are you an iRiver Computer and Internet Expert? Answer questions, earn points and help others
