Question about GE Profile Spacemaker JVM1871 Microwave Oven
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
Posted by robertw8 on
Chuck
    Sergeant:
  • 228 Answers
Usually a odd sounding hum combined with an unusual smell is caused by the magnetron. Another source is from the high voltage transformer or diode.
Posted on Feb 25, 2015
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Posted on Feb 06, 2011
My Rusell Hobbs 20L microwave wont heat food,what could be the problem?
If the control circuit turns on the power supply to the magnetron tube, the big power transformer should hum. Then after a couple seconds, it should hum louder as the magnetron warms up and starts to put out RF. If everything stays stone cold, the magnetron is probably shot.
These are repairable, and the parts are available. But you have to decide whether it is worth repairing. If it's past warranty, probably not. I am a radar transmitter engineer with 40 years' experience with these kinds of tubes, and if my ten year old microwave quits, I'm going to just throw it out (after I take it apart just to see what quit).
Apr 06, 2017 | Microwave Ovens
My GE over the oven microwave does not heat (1.5 years old). The heating and turntable stopped working at the same time. When you start it, it sounds fine, but nothing heats. You can hear a relay or...
It does sound like a relay malfunction or similar switch. Could be repaired but call for a quote or better yet, take it to a repair depot (probably cheaper).
Dec 13, 2014 | GE Microwave Ovens
My LG Microwave (LRM1250W) does not heat all of a sudden
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p]][p
Feb 17, 2010 | LG LRM1230W Microwave Oven
Microwave make a deep humming sound ,does not heat and the circuit breaks
I would say your magnetron has failed.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the one-year time frame, the repairs should be free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Samsung SMH7178STD Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Will not heat.
Hi I've been out of the microwave repair business for a few years now, but the technology has remained virtually the same as far as I know. You obviously have some knowledge of them, as you know about the safety switches in the door. Microwave ovens are actually a very simple device, to test it, put a coffee cup of water inside, and set the unit on high for one minute. A second or two after you hit the start button, you should hear a fairly loud "bong" noise, and a hum that continues untill the time runs out. That noise is the magnetron starting up, and if that noise does not happen, then the magnetron or related circuitry is probably bad. NEVER open up the oven, as the magnetron may be charged, and must be discharged by a technician. If the sounds that I described are present, then the water should be boiling or close to it in one minute, if not,then something I've never seen has gone wrong. Assuming you had a year warranty on it, I know from experience that if you contact Goldstar customer service by phone, or letter, they will often extend their warranty a month or so to keep happy customers. Its worth a try. Hope this helps you out. P.S. Never operate a microwave without something inside (Non metalic)
Nov 30, 2006 | LG LMV1925 Microwave Oven
GE Profile Spacemaker JVM1871 Microwave Oven Logo
342 people viewed this question
Top GE Microwave Ovens Experts
gbob59
randymanfive
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
