when you order parts it goes by model number, from what I can see there are several different model #'s for the Oster Versa,
BLSTBV-RV0-000 and BLSTVB-000-000.
try here, type your model # in the search area at the top. Oster Blender Parts
or here, Oster blenders lids blenders jars caps at Goodman
or here, under parts & accessories Oster Parts Accessories Oster
I haven't found any where in Australia to get them, you may just have to get them on line.
If the motor runs in reverse to an Oster which uses counter clockwise thread then it follows that your thread should not be counter clockwise. If it comes loose when you turn it on surely the thread on the coupling must be faulty because according to your description the action of turning it on can only be to tighten the coupling. Most couplings with a thread that I have seen are counter clockwise so you will probably struggle to find another brand coupling to match.
Hold washer w/ vice grips and turn stud counter clockwise with box end wrench, small crescent wrench, or another vice grip. Should turn fairly easily at first then finger loosen. A 50y/o model 541 continuously exposed to salt sea air gave no resistance at all w/ this method.
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives. This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
This just happened to me too, and I think I just fixed it. First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99). I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are. Remove the rubber skirt to reveal four screws that hold the motor in. They are way in there so you'll need a long screw driver. Remove the motor and unscrew the old coupling. Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck. I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks. If your blender is the same, remove the bottom nut, fan blade and two washers. This gave enough of a rod to grip to get the old coupling off. (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck! Hope that helps!
