Question about Vector VEC024B MAXX SST Power Inverter
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
Posted by wisecarmen on
tomtij
    New Friend:
You would need a pure sign wave inverter for any electronic equipment to work at its best, the playstation3 will not work on any other inverter. this only outputs 110v I that it the TV is set at 110v.
Tom from www.automotivetechnical.co.uk
Posted on Feb 03, 2013
joe leier
    Novelist:
  • 185 Answers
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Posted on Feb 06, 2011
Do I need to put a inline fuse or does the vector sst 1200 have a fuse or breaker in it
It probably does, but an in-line fuse is still the safest way to go, connected as close as possible to the voltage source as possible. The internal overcurrent protection device (aka, fuse or breaker) in the inverter will prevent the DEVICE from melting if it malfunctions. An in-line fuse will protect EVERYTHING if the WIRING malfunctions.
May 05, 2014 | Vector ® Maxx SST 1200 - watt Power...
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Dec 22, 2010 | Vector VEC024B MAXX SST Power Inverter
My name is Gena. The VEC024B that is being used by our field technicians are having problems with the fuse blowing in their work vans. Their vans are equipped with laptops.
Hi Gena, the inverter is a 400 watt unit. This is not a rating for a continuous load. You do not mention which fuse is blowing. This could be the fuse in the inverter or the cigarette lighter (power source) fuse. In either case, a fuse blowing could be a short circuit, something in the inverter shorted, or too much load. I am going to look at the too much load side of things. Not knowing how many laptops are being used, with the inverter if you have a 20 amp fuse in the cig lighter, this will allow you 20 amps X 12 volts = 240 watts. I would not run the inverter over 240 watts because of overheating issues. So, 240 watts will run 3 laptops. Just the laptops. Most laptops draw around 70 watts. check your power supplies on them to find their rating. If you exceed the 240 watts by combining the ratings, then you can expect trouble with your inverter. It will give 400 watts, but this is a temporary condition only. Another inverter will be needed or a larger one installed and it being connected directly to the battery (with a fuse of sufficient size installed). You could also (let us say there are 6 computers) charge and run 3, and the other 3 are running on their batteries. After an hour, switch so that the 3 running on batteries now are charging as well as running. The other 3 are now charging.
I hope this helps. If you have any other questions please provide additional information. Such as the size and location of the fuse blowing. The laptop power supply ratings.
thank you
Oct 15, 2010 | Vector VEC024B MAXX SST Power Inverter
I need help hooking my vector maxx sst 1000 w power inverter to my car
A 1000 watt power inverter hooks to the battery terminals directly, not through the cigarette lighter.
Jul 20, 2010 | Vector 1000w Power Inverter
Will not turn on
sounds to me like there is a dead short somewhere in the system, I would take it to an electrical appliance repair shop and they can fix it. If there are none in your town then look on the internet for one in your state so you won't have to send it very far to get it fixed.
Jul 14, 2010 | Vector MAXX SST 500 Watt / 1000 Peak Watt...
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Lighter cord needed
Purchase a replacement from any auto supply store.
Jun 16, 2009 | Vector VEC024B MAXX SST Power Inverter
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
Vector VEC024B MAXX SST Power Inverter Logo
379 people viewed this question
Top Vector Electronics - Others Experts
Marvin
Marvin
Lawrence Oravetz
Steve Cox
Steve Cox
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
