Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Water is accumulating under the vegetable bins on my 12 year old kenmore cold spot 70172990. The refrigerator keeps every thing cold and the freezer is fine too, just the accumulation of water. Understand something might be clogged....just don't have manual and dont know what exactly i am supposed to do to clear it. Wear is the drain or pipe that needs cleaning? Help!
Posted by carmanni on
wingnut
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Try looking at the vent on the lower shelf on the left hand side. Make sure it is not covered and it is not clogged with dust or 'food' items.
Posted on Sep 07, 2017
5 Related Answers
Anonymous
SOURCE: Water accumulating in top shelf of refrigerator
I solved this by emptying everything in the freezer and taking out the floor of the freezer (2 screws - simple) and finding the drain hole covered in ice. I used a blow dryer to melt the ice. Then I used a turkey baster to place boiling water into the drain hole, waiting 30 seconds, using the baster again to remove the cooled water and reapeating this until the ice in the drain tube melted. You can tell when the ice in the drain tube melts completely as you can hear the water falling into the pan in the bottom of the unit (under freezer and refrigerator).
Posted on Apr 05, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: water accumulating under the fruit and vegetable
If you look behind the panel inside the fresh food section there is a drain coming from freezer and then to outside back and down to a tray next to compressor. The drain is most likely blocked there. Let me know if I am wrong, Sea Breeze
Posted on May 21, 2009
rmaazar
  • 13 Answers
SOURCE: Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Posted on Jun 20, 2009
Jose Pino
  • 563 Answers
SOURCE: water accumulating in vegetable bin on model
This is caused by a clogged drain tube or the door is not closing correctly. Be sure the seal around the fridge door is closing correctly. If not, the drain tube needs to be replaced or cleaned.
Posted on Nov 06, 2009
ken thomas
  • 6 Answers
SOURCE: water accumulates under vegetable bin
If this is an older style top mount refrigerator than most likely the drain is clogged causing the water to leak into the fridge during the defrost process. What's the model number?
Posted on Jul 06, 2011
Ge model number tbx21jaxerww. Water collecting under vegetable bins
The water building under the veggie bins problem is usually a result of the drain under the evaporator coils being clogged with either ice or debris.
The get to the drain, the shelves and sometimes the bins will need to be removed, then the back panel will need to be removed. There usually are a few screws on each side that hold the panel in place...
Then look for the drain right under the coil....if possible run a wire down the hole to make sure it is open to the pan underneath.
If it is frozen then a wire can be used to keep the drain open...here is a tip about how to do that...
WaterRunning in refrigerator from Freezer
heatman101
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Jan 27, 2009 | Kenmore Refrigerators
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Water inside the refrigerator
check for a door gasket problem on one of the doors if it is not sealeing all the way you will get moisture in the fresh foor section and additional forst in the freezer
Jun 10, 2008 | Refrigerators
Too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
