Question about Canon Cameras
I have a Cannon EOS Rebel xsi SLR camera. When I look through the viewfinder the image is blurred. IT worked fine the last time I used it, but this time it is blurred and I haven;t been able to correct it. Please advise.
    New Friend:
  • 6 Answers
Two possible situations. It might be that the lens focusing system isn't working. Try focusing by hand (turn the lens manually) If the image moves through a point of sharp focus, then you have a lens or focus motor problem.
More likely, you have improperly adjusted the diopter. There is a small, circular wheel on the right side of the viewfinder, toward the top corner. It is sometimes covered by the rubber viewfinder hood so you might not notice it. This adjusts the diopter correction in the viewfinder and if it's set wrong, nothing will ever look in focus. The pictures would be fine, but since the diopter is a correction for your eyesight, the viewfinder will be out of focus.
Posted on Feb 06, 2011
6ya staff
SOURCE:
Can not see subject through the lcd screen
Um, no. EOS Rebel is a "single lens reflex" camera. The display on the back does not show live image. Use the viewfinder above it. After you take a picture, the picture will show on the screen for a few seconds.
Nov 16, 2015 | Canon EOS Rebel XSi Digital Camera
My rebel canon camera doesn't show up on screen when taking pictures only after I take them
I presume you're asking about a Digital Rebel and not a 35mm film Rebel (as per the question heading).
If so, that's probably normal. It's only relatively recent dSLR models which have a "live preview" facility (often wrongly called "live view"). The whole point of an SLR is that the viewfinder is the main compositional viewing tool; the LCD is there solely to display and adjust camera functions and to review images already captured.
Most current and recent SLR's now have live preview, and all true SLR's are incapable of viewing the image at the actual moment of image capture as the viewfinder mirror must flip up out of the way of the image sensor.
If you want live preview then you must change your camera. if you tend not to use the viewfinder anyway then consider mirrorless Compact System Cameras such as the Olympus and Panasonic Micro Four Thirds models as they do have a true live view capability and the LCD is the main (or only) tool for composing images. Panasonic also have their regular Four Thirds G range, which look like an SLR but have an electronic viewfinder and they are also capable of true live view.
Sep 22, 2011 | Canon EOS Rebel X 35mm SLR Camera
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
I have Cannon EOS Rebel xsi. The camera does not take picture when press the shutter in all modes. There is no error message. Have change the memory card, recharge the battery and none work.
Hello Sure !
The probleme :
The Shuteer Has A cable Connected to Recorder
Maybe The cable Has Cutted when you Shut ,or Maybe Cutted When You Charged The Battery cause When your put your camera on the charge , the cable goes be hot and it should be cutted .
Solving The Probleme :
1) I advise You To Change The Cable
2) Push The Reset Button
3) Charge It Again
It works 100%
Fix-shad0w
Aug 03, 2010 | Canon EOS 10D 35mm SLR Camera
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Canon 15-55 zoom: won't auto focus. My 70-300 on
focus ring on cannon ef70-300 zoom is stiff, jerky. how can i free it up.
Mar 14, 2010 | Canon EOS Rebel XSi Digital Camera
The metering screen inside the viewfinder keeps flashing BUSY, and the display screen will not show anything.(Canon Rebel XS Digital SLR)
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Mar 01, 2010 | Canon EOS Rebel XSi Digital Camera
The viewfinder is black except for the display or directly after i take a picture
If you're using the screen to set up your shots, the viewfinder is disabled, and vise versa. It only works one way at a time.
Oct 20, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Cannot download pictures Canon Rebel Xsi
Create a folder on your desktop. Use the cardreader to download to it.
Aug 29, 2009 | Canon EOS Rebel XSi Digital Camera
Is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Sep 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
132 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
