Question about Casablanca Fan Televison & Video
Remote control have become sticky -- cleaning seems to make it worse.
Posted by tnddamico on
  • 1957dvorak
    1957dvorak Jul 09, 2013
    I have two of these remotes and they are the same way, sticky, and the more you try and clean them just makes them worse.
  • 1957dvorak
    Would be nice if Casablanca would send me new units.
D Bisirri
I have 3 very sticky Casablanca Fan remotes. I called their customer service who had me try to remove the disgusting sticky surface with Lysol wipes, rubbing alcohol and vinegar, none of which worked. They then provided me with a link to purchase 3 new remotes at $40 each. My remotes are only 6 years old and used about 10 weeks out of the year in a vacation home. I told Casablanca that they lost a good customer as I currently own 5 of their fans. I will never buy another Casablanca or Hunter fan since they refuse to correct my sticky remote issue. The plastic is obviously breaking down and should be considered a manufacturing defect. I have a Harbor Breeze remote for a Harbor Breeze fan that is also 6 years old and that remote is like new. Don't waste your money on a Casablanca ceiling fan, you won't want to use the disgusting remote in about 4 years which is when mine started feeling sticky.
Posted on Jun 30, 2020
M. Hagen
I have the same problem; the remote has become quite disgusting to touch. I recently sent a complaint to the company via the customer service page on the Casablanca Fan web site. They are sending a replacement, no questions asked, so clearly the problem is known to them and they have no solution other than replacement.
Posted on May 27, 2012
How to clean a sticky remote control
It can be cleaned using methelated spirit or ethyl alcohol. Never use Petrol or like vigorous active solvents. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jun 10, 2015 | Vizio Televison & Video
Buttons are sticking
Hi Pamela
Common problem
Hold remote upside down while cleaning with a damp cloth and tooth brush. Clean Cracks.... e.g. needle
Keep food and sticky stuff away from remote or any keyboard
Apr 07, 2015 | Televison & Video
Can not change channles with the up and down arrows
William,
Sticky buttons or entirely non-working buttons are symptoms of a worn out microboard. After pressing a button so many times the microboard beneath the buttons will eventually become nonfunctioning. You will need to replace the remote.
Thanks,
Dish Guy
Aug 07, 2012 | Innovage Jumbo Remote Control
How to clean the sticky rubberisth remote nothinbg was spilled on remote it is just sticky...has a rubber back
Rubbing alcohol and alcohol and a few cotton balls.
step 1.)
With a alcohol moistened cotton ball (not too much alcohol)
clean the back of the remote.
step 2.)
Dry remote off, with a dry cotton ball
step 3.)
Enjoy your new non-sticky remote control :-)
Sep 24, 2011 | Dell C6129 Remote Control
The volume on the TV keeps going down by itself. What should I do?
Dont know what tv you have but. You can remove the batteries from remote and if volume still goes down you ruled out the remote as the problem.. Or just take remote to another room. If the problem still exists then Im guessing either a sticky button on the tv volume down or as I have seen to many times.. People clean their tvs with windex or some cleaner and it drips down into the tv messing up the control buttons. Hopefully its just a sticky button..
Oct 19, 2010 | Toshiba CT-90157 Remote Control
The batteries in our remote seem to be going
stuck button. tear apart unit, clean circuit board with Q-tips. Clean pushbuttons to remove any sticky gunk and try again.
Dec 20, 2009 | Kitchen Appliances - Others
Hunting at idle-worse cold,slight missfire at top end,done the leads,tightened manifold,checked fuel pressure,volume & injectors-no codes when scanned -checked coils,plugs etc-appears to be running...
Sounds suspiciously like it could be the Idle Speed Control (ISC) motor on the side of the throttle body. They can tend to carbon up and become sticky. Try removing it and cleaning it out with throttle body/carb cleaner. This motor controls additional air into the inlet system. If it is sticky is does not react smoothly and in time with the request from the ecu, it will cause hunting. It may also be a good idea to check the oxygen sensor while your at it, although surprisingly, in all the info I've got I cannot find resistance figures for it.
Jul 30, 2009 | 2005 Ford Futura
Sticky controls
Oh boy, ocean water has salt in it, which just
eats away at the electronics of the camera.
Salt water is worse than fresh water, but any water can cause damage.
Apr 15, 2009 | Olympus FE-210 Digital Camera
I have a playstation two remote control that it seem that the buttons get sticky and will not fully return to the neutral prosition. I want to fix it because it is a wireless remote that caust me $39.
Try taking it apart and cleaning the rubber number pad with alcohol and let dry before putting back together this should help.
It seems to have have something spilled on it.
Mar 08, 2008 | Video Game Consoles & Games
Televison & Video Logo
1,601 people viewed this question
Top Casablanca Fan Televison & Video Experts
deton8 von Splosion
Tom Chichester
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
