Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
I have a EOS Rebel XS camera with a 18-55mm lens. Every time I try to zoom in both lens and the picture are blurry. Am I just in the wrong settings?
Posted by juliegrint on
sameerak47
    New Friend:
  • 23 Answers
Make sure the lens is not in manual mode. on the side there is MF and AF make sure its in AF for auto focus. id its still looking nblurr in the viewfinder when pressing the shutter half way then user the smal wheel next to the viewfinder so the viewfinder is calibrated for your eye.
Posted on Feb 26, 2011
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
While taking picture with my Canon Rebel xs when you look through the lens it's blurry why is that?
I'm gonna state the obvious and suggest the lenses may be dirty. If cleaning the lenses with a cloth doesn't fix the problem, send it for repair because it may be an internal problem you may be unable to repair yourself without the proper tools and know-how.
Jun 29, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
How to zoom in using Canon EOS Rebel XS?
Zooming is done from the lens on a DSLR, assuming you have a zoom lens on the camera. For example, if your camera came with the 18-55mm lens, you should see the numbers 18, 24, 35 and 55 on the lens barrel with a white index line next to one of the numbers. Turn the barrel to move a different number next to the index line. 18mm is wide angle, 55mm is 'zoomed in'.
Mar 12, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel xs Battery and error 99 problems
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Sep 26, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Sep 30, 2006 | Canon Digital Rebel XT / EOS 350D Digital...
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
210 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
