To adjust the startup volume on a Bush DAB NE 3125 radio, you can follow these steps:
Turn on the Radio: Switch on the radio by pressing the power button or any other designated button.
Locate the Settings Menu: Look for a "Settings," "Menu," or similar button on the radio. It is usually represented by an icon or labeled accordingly. Press the button to access the settings menu.
Navigate to Volume Settings: Within the settings menu, navigate to the volume settings options. The exact location and naming of this option may vary, so refer to the user manual if needed.
Adjust Startup Volume: Once you've located the volume settings, you should find an option to adjust the startup volume. Use the volume control buttons or a designated adjustment knob to increase or decrease the startup volume level to your preference. Some radios may use a numerical scale or percentage system to represent the volume levels.
Save and Exit: After adjusting the startup volume, save the changes by following the instructions on the screen or pressing a designated button such as "OK" or "Save." Exit the settings menu to return to normal operation.
Note: If you're unable to locate the volume settings within the menu or the settings menu does not provide an option to adjust the startup volume, refer to the user manual specific to your Bush DAB NE 3125 radio. The manual should provide detailed instructions on how to adjust various settings, including the startup volume.
If you don't have the user manual, you can try visiting the Bush official website or contacting their customer support for assistance in obtaining a digital copy of the manual or for further guidance on adjusting the startup volume.
Right click on the megaphone located at the bottom right near the time. You can adjust the volume there.
Look on your keyboard and normally you can Press and Hold the FN function key located at the lower left portion of the keyboard then hit one of the 3 keys with the megaphone that adjusts the volume (1 key increases the volume, 1 key decreases the volume and 1 key mutes the volume).
You can adjust the volume in the Control Panel's audio or sound properties. Click Start/Control Panel and look for Sound or Audio.
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Adjusting the volume on an HP Officejet All-in-One Follow these steps to adjust the volume of the various fax sounds. Adjust the rings and beep volume 1.Press the Setup button P(wrench). 2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK . 3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK . 4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK . Adjust the phone line and monitor volume 1.Press the Setup button (wrench). 2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK . 3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK . 4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK . Adjust the handset volume When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume.The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
is the volume of your tv adjust automatic with a volume indicator on the screen appear?if that the case clean the volume controls on the mainboard with a contact cleaner..2nd is is the volume adjust with no volume indicator on the screen?your problem might be onthe sound if section.adjust the sound IF with a plastic screwdriver clockwise or counter clockwise until the soun stabilises..adjust the IF with a power is on.
The Volume key allows you to adjust the volume level for the currently active audio device (handset, headset, or speaker). When no audio devices are active, pressing the Volume key adjusts the ringer volume.
Adjusting the Volume of the Ringer, Handset, Headset or Speaker Note: By performing this function, default volume level will be replaced.
Press the up or down arrow at either end of the Volume key to reach the desired volume level.
When you are satisfied with the setting, press the Save softkey.
Note: When adjusting only the ringer volume, there is no need to press Save. The settings are automatically saved upon adjustment.
There are 3 types of volume: master volume, in-call volume, and multi-media volume. To adjust master volume, press and hold the thumb wheel until the volume control comes up and use the wheel to adjust it. When in a call use the thumb wheel to adjust the in-call volume. Finally, use the thumb wheel to adjust the volume of multi-media while it's playing. One thing to keep in mind, the master volume will override the multi-media volume, so if you can't hear the multi-media after turning it all the way up, you might try raising the master volume fist.
