SOURCE: Nikon FE- Winder return position
YES, THE PROBABLE CAUSE IS THAT AFTER 25 YEARS OF USE YOUR POOR NIKON PROBABLY JUST NEEDS A GOOD CLEANING! I DON'T THINK IT IS ANYTHING A GOOD CLEANING CAN'T CURE. I HAVE INCLUDED A COUPLE OF SHOPS THAT REPAIR NIKONS AND GIVE FREE ESTIMATES. WHILE I DON'T ENDORSE ANY REPAIR SHOP PERSONNALLY, I PASS THESE ALONG FOR YOUR INFORMATION. I HOPE THIS HELPS. I REALLY BELIEVE THIS WILL TAKE CARE OF YOUR PROBLEMS. ALSO, BY THE WAY, I ALSO HAVE A NIKON FE AND IT'S A GREAT CAMERA. ENJOY!
www.keh.com
www.camerarepair.com/camera/repairs/264-NIKON-FE
THESE ARE HOTLINKS AND WILL TAKE YOU TO THE PAGE.
SOURCE: shutter fires when film advance lever is used.
The problem you describe is common with the EM. I have one myself sitting on the junk pile for the same reason. The body is made of plastic and the plastic around the advance lever is a week point. Your body, unfortunately is not repairable. But there is good news. Because of the low cost of a replacement EM on E-bay (under $30), you should consider keeping your lenses and buying a new body (the standard 50mm f1.8 EM is superbly sharp for a low end lens). Since the EM lenses are interchangeable with later models, you could consider a later model used body. Many are selling for fire sale prices.
SOURCE: nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
SOURCE: Nikon EM (1979?) Won't wind film, photos don't come out
Not necessarily. The EM has an M90 setting which will fire the shutter at 1/90th of a second. The meter is inactive on this setting. It was put on the EM so that if the batteries fail, you can shoot at 1/90th and take a guess at the exposure. There is also a small button (blue or chrome, depending on the production run) which lights up a red LED if the batteries are good. The light meter doesn't work until the frame counter is at 1 or higher. Before the #1, the shutter will always fire at 1/2000th of a second to speed up the film loading process. You can tell that the meter is working by observing the meter's scale/needle on the inside of the viewfinder. If it is pointing out of the red zone, it's OK to shoot (proper exposure). If the needle is in the red zone (indicating under or over exposure) the camera will "beep" as an audible warning. Check the battery condition first.
SOURCE: how do I change the shutter speed on a Nikon EM
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
