Question about H2O Audio Intova H2O Man MP3 Player
My H2O Man Mp3 player won't charge - light stays red (solid) when plugged into my computer. When I put it back together it won't turn on at all.
Posted by Cori Clews Jahn on
William Matsumoto
    New Friend:
  • 67 Answers
Hi Northernelf,
Please contact Intova directly at (808) 837-0074 or e-mail [email protected] and we will gladly help to address the problem with your H2O Man MP3 player.
Thanks,
Intova
Posted on Feb 07, 2011
My H2O man mp3 player will not charge. Red light indicates charging, but never turns green. Is this typically the charger or the player? And can this be replaced or repaired?
Hi Sharonpat2,
It sounds like your charger is defective. Please contact Intova directly at (877) 837-0074 or e-mail [email protected] and we will gladly help to address the problem with your H2O Man MP3 player.
Thanks,
Intova
Mar 27, 2012 | Audio Players & Recorders
It wot update
Hi phillipw598,
Please contact Intova directly at (808) 837-0074 or e-mail [email protected] and we will be able to help you with your H2O Man MP3 player.
Thanks,
Intova
Feb 07, 2011 | H2O Audio Intova H2O Man MP3 Player
My H2O man doesn't seem to read the card my songs are loaded on. I converted the files to MP3, but it still doesn't play. The blue light blinks fast then turns red.
If the player blinks blue really fast then red it can only be one of two things.
One: The bracket that goes over the micro SD card is not slide up and locked into place once the card is inserted or
Two: One of the songs loaded on the micro SD card is in the incorrect format. Try playing just the songs that came on the player first. If thoughs work then load 10 new ones on and see if they work. Keep gradually adding songs until the player stops working to help find the problem song.
If you have further questions please call Intova at (808) 837-0074 or e-mail [email protected]
Thanks,
Intova
Dec 25, 2010 | Snap Sights H20 Man MP3 Player
It won't turn on even after being fully charged and reset button pressed.
If the player is accepting the charge meaning the solid green light is shown on the charger when the player is attached to it but is not powering on there may be a problem with the players circuit board. Intova does offer a one year warranty with all our products and will be more than happy to issue you a RMA number and exchange the player. Please contact Intova at [email protected] for quick turnaround. Take care.
Sep 29, 2010 | H2O Audio Intova H2O Man MP3 Player
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    Nextar MA 166 MP3 Won't Charge
    You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
    -Tha Mp3 Doctor
    Jan 24, 2009 | GPX ML648B MP3 Player
    My zen stone stays on a solid green light
    Just tried this on a zen stone with speaker and worked. Connect your zen stone to your computer. When the green light is on, use a paper clip and press and hold the reset button (small hole on the headphone jack side). The green light should turn off. Wait a bit and it should start blinking to indicate it is now charging. Note: This reset only worked when I had it connected to the computer.
    Hope it works for you too.
    Ken
    Nov 22, 2008 | Creative Labs ZEN Stone MP3 Player
    My Mambo- Mano MP4-MP3 does no charge
    it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
    Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
    Jazz DV-179
    YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
    Jul 12, 2008 | Jazz DV-179 Digital Camera
    WON"T WORK
    sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
    May 08, 2008 | Jazz DV-179 Digital Camera
    H2O Audio Intova H2O Man  MP3 Player Logo
    218 people viewed this question
    Top H2O Audio Audio Players & Recorders Experts
    Muntejaya Ginting
    Muntejaya Ginting
     Grubhead
    Grubhead
    Are you a H2O Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
