Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
Flashing code has told us that the anti flood device has activated on our Zanussi ZSF6128, any suggestions as to what this could mean and how to fix it. Thanking you
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
Anonymous
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Posted on Jan 10, 2010
joe_lishman
Joe Lishman
  • 192 Answers
SOURCE: anti flood device has activated on my zanussi
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
Posted on Jan 18, 2010
Marc Helfrich
  • 56 Answers
SOURCE: anti-flood device activated
Check your debris trap usually found at the bottom of dish washer and clean. May need to reset or unplug to reset devise. See what happens after cleaning, good luck, best regards.
Posted on Jan 31, 2011
Zanussi dishwasher anti flood device
There is a water level pressure switch that is your issue. Replace that or if youre lucky, clean the hose/pipe connected to the pressure switch and it could work again.
Feb 10, 2016 | Zanussi Dishwashers
What is code.30
Zanussi ZDF 511 User Manual
anti flood device is activated,call for service
Mar 31, 2015 | Electrolux Genuine ZANUSSI ZDF511...
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Dado
Sep 01, 2014 | Zanussi Dishwashers
What does fault code e30 on a zanussi jetsystem 1400
Activated anti-flooding device. Try to find leaks in the bottom of washing machine.
Dado
Aug 08, 2014 | Zanussi Washing Machines
How to fix code i30
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 01, 2014 | AEG 23 in. Favorit 86070Vi Built-In...
Anti-flood device activated
Jan 30, 2011 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
Jan 18, 2010 | Dishwashers
Mar 22, 2008 | Dishwashers
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
152 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
