Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Every time i plug my 1TB western digital mybook in my computer freezes and when i shut it down it wont restart until i unplug it from the computer i have no idea what it could be please help
Posted by fhwrestler16 on
Anonymous
    Scholar:
    New Friend:
  • 105 Answers
That needs a motherboard drivers upgrade.
What happens is that the BIOS starts detecting and checking booting devices.
Earlier motherboards are not able to detect external hard drives and boot from them.
So the solution to this is to turn off the computer and then disconnect the cable.
Remove safely the HD and then restart.
God Bless You!
Posted on Feb 05, 2011
Computer not recognizing MyBook when plugged in
Have a look at this article on external hard disk troubleshooting. Could be that you need to delete the USB root hub devices in the Device Manager to force Windows to recognize the device.
Jun 24, 2010 | Western Digital 320GB MyBook External USB...
My wd 1tb mybook no longer powers up-I have archived versions of these files but i would prefer to get the data off this drive
Is it still under warranty?
Possibilities:
* try connecting to a different USB port on your computer
* try connecting to a USB port on a different computer
* try a different USB cable between the computer and the MyBook
* disassemble the casing, and remove the disk-drive, and connect it as a "slave" drive in some desktop computer, to see if the files on the disk-drive are intact
If all else fails, search online for "professional data recovery service" -- a company that will repair the MyBook just long enough to copy all your files onto a new disk-drive. Of course, this is _expensive_.
Note that Western Digital has a Customer Loyalty Program -- knowing the serial-number on your disk-drive, you can buy a new MyBook from their web-site, at a good discount.
Apr 23, 2010 | Western Digital My Book Essential 1TB...
Samsung 1tb external will not allow my computer to boot
Try checking your bios to see what harddrive the computer boots from.
Your PC might be trying to boot from that samsung story which I assume doesn't have an OS installed.
Cheers
Oct 09, 2009 | Western Digital MyBook Studio 1 TB USB...
My Western Digital 1TB hard drives do not power up when plugged into the USB Ports. No Blue light no nothing. I am however using the same power cable. I have changed the USB cable.
Seems like your case power is broken, check your warranty or buy a new one. to get your data back, open the case and unplug your harddriver, plug your driver in a PC computer and remove your important data.
You could also test a new power cable because it seems like your case doesent get any.
Aug 17, 2009 | Western Digital MyBook Studio 1 TB USB...
Western Digital 1T MyBook keeps crashing
it seems a problem with the driver, try plugging it onto a different computer. If that works, reinstall the driver.
Aug 14, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Computer freezes on start-up when western digital 1tb external hdd plugged in to computer, computer starts fine with it unplugged. The hard drive can be plugged back in after start-up.
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
Aug 11, 2009 | Western Digital MY BOOK HOME 1TB EXT...
My Western digital 1tb wont work inspite of drivers being instal
Mybook does not require any additional driver to work on systems from Win XP onward, same for recents Linux and MAC OS.
If the drive is not detected on more of one computer, then it is usually because of a fault.
Try a replacement cable (mybook uses Mini USB to USB, available at computer and at camera shops). If still no luck contact WD, mybooks have one year warranty. If you want to recover data, the disk must be mounted on a different enclosure, that service can be asked when discussing repair.
Regards
Jul 12, 2009 | Western Digital My Book Essential 1TB...
MyBook 1TB will not power on anymore. I have(had) mydocuments pointed to it and it has worked fine until today. My pc said it could not open the selected drive because it was not there. So I unplugged the...
I have the same drive guy. take a voltage meter and test the power adpator and see if your getting the right power to the unit. Check your usb ports as well even try it on another computer to diagnose your own. Try these steps good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Western Digital MyBook Studio 1 TB USB...
WD 1TB working properly for some time
Make sure the power supply (power brick) for the mybook is working. (unplug both ends or the power cable and plug back end)
do the same for the USB cable. Still no luck? Plug the USB connector into a different port on the PC and see if that changes your luck.
Feb 27, 2009 | Western Digital My Book Essential 1TB...
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
Top Western Digital Computers & Internet Experts
efs_perpends
efs_perpends
Mike
Michael Thomas
Michael Thomas
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
