Symantec Norton Internet Security 2009  Logo
Question about Symantec Norton Internet Security 2009
Symantec Norton Internet Security 2009 Run liveupdate
Posted by blkperl2000 on
Anonymous
    Scholar:
    New Friend:
  • 112 Answers
I see that you are using an older version of Norton Internet Security. I suggest you to update your program to the latest version. You can download the installation file from the link www.norton.com/nis11 and follow the onscreen simple instructions. I am sure that upgrading to the latest version will fix your Live Update issue. Please also check if the computer's date and time is correct.
Regards,
Muhaim
Posted on Jun 08, 2011
I ordered security on symantic store on 27 jan confirmation #8122987214 norton 360 version 134.99 extended download service 14.99 and my computer is saying i am not protected
1 of 2 things is happening
1. Software did not install correctly
2. Run the LiveUpdate tool provided in the software.
Most likely you just need to run your updates.
Thanks
MyLive-Tech 1-888-361-8511
http://www.mylive-tech.com
1helpful
Have norton all-in-one-security but won't load
error message actually points to a LiveUpdate problem,which could just be a problem with your installation. Instead of uninstalling Norton and reinstalling it, please try the procedure below.
Please click on the link below and follow the instructions carefully.
Fix for LiveUpdate Error
After you complete the steps in this document, please check that your LiveUpdate settings by doing the following:
1. Launch Norton Internet Security from Start-.>All Programs->Norton Internet Security,> and then choose "Norton Internet Security" from the sub-menu.
2. Click on the "Norton Internet Security" tab at the top of the window.
3. Click on the arrow next to "Settings" to expand it's options.
4l. Next click on "Automatic LiveUpdate." It should say "On." If not please click on it and then click on the "Turn On" button. When Automatic LiveUpdate is turned on, as long as you are connected to the internet and logged in to Windows, LiveUpdate will check for and install updates up to 3 times per day. This is the best way to keep Norton Internet Security up to date and running smoothly.
Full system scan not getting completed
Open NIS and run LiveUpdate. Keep re-running LiveUpdate until it says that there are no more updates. Reboot the system if prompted to do so (you may want to reboot even if it doesn't say it is required, just to be sure everything got replaced properly). Open NIS again, select Tasks and run a Full System Scan. The error message should not appear again.
2answers
Cannot enable symantec antivirus in Vista
1. run the liveupdate
2.click on start and inside the start search type msconfig check whether it is in selctive or normal startup (it should be normal startup) change the date to one month before and run the liveupdate again and restart the computer
Norton antivirus liveupdate
1) Close all Norton applications.
2) Moved file [ccWebWnd.dll]
from [C:\Program Files\Common Files\Symantec Shared\]
to [C:\_My Files\_TEMP]
3) Run LiveUpdate
Type [C:\Program Files\Symantec\LiveUpdate\LUAll.exe]
into Windows Explorer Address bar and hit [Enter]
4) Restart your computer.
5) Moved file [ccWebWnd.dll]
from [C:\_My Files\_TEMP]
to [C:\Program Files\Common Files\Symantec Shared\]
6) Run Norton SystemWorks LiveUpdate from your Windows Start Menu.
7) Restart your computer.
1helpful
2answers
Processing liveupdates failed
If your using windows XP:
1) go to start, then RUN
2) on the run box type LUALL and take note of the error
If your using WINDOWS VISTA:
1) on your keyboard look for the window/flag button and hold it down and press "R"
-POST here the LU.. error
-for shortcut try uninstalling and reinstalling the product
I wish to install Windows Vista Home Premium. I already have Windows XP. I pay for Norton Internet Security by direct debit through Tiscali and have done so since, 2006. I have run Norton Liveupdate. ...
You will need to cancel your Norton subscription and use one of their products that is suitable for Vista. May I suggest that you purchase Norton Internet security 2009 for a single payment of about 70 dollars.
Top Symantec Computers & Internet Experts
David Shaub
Steve Nordquist
Steve Nordquist
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
