Question about Motorola Cell Phones
I need my sim puk code and customer service is closed
Posted by ayoxthimer on
Chris Hingee
  • Motorola Master
  • 32,281 Answers
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Posted on Feb 05, 2011
Accidently locked new h2o sim card need puk code
If you still have the card where you removed the simcard just check on it they write it there, or if you dropped the card then Visit You nearest customer service center they will unlock the simcard for you.
Check Image for example
Nov 23, 2015 | Cell Phones
I need a puk code for samsung T528G, customer service is closed
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
Aug 29, 2011 | Samsung Cell Phones
I have a alcatel cell phone that i messed up the pin to many times and now its asking for the puk code i dont know it and the provider customer service is closed i need the code asap to call out of work...
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software...
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Aug 26, 2011 | Cell Phones
I tried to enter the pincode for 3 times but the pincode blocked then the phone said enter the puk code then the sim card is rejected
Hi There,
  • This is a usual problem which occurs when an incorrect code is entered multiple times , when the phone is requesting for a PUK code,and eventtually the SIM card getls blocked after multiple incorrect codes or gets rejected.
  • May people are not aware from where can they get this PUK code,
  • The PUK code is provided by the SIM card's service provider , for instance , if your SIM card belongs to vodafone , then you need to call up vodafone customer service or helpline number and they will give you the PUk code after a usual ID check.
  • I would also like to inform you that people usually ask for a PUK code when their SIM card is locked and it's requesting a PUK code so they use their friend's cell phone to call up the customer care asking for help , however you can get the PUK code on the very day when you bring a new SIM card by asking the relevant executive in the service provider's gallery or calling up customer care.
  • Now all you need to do is get a new sim card , and ask for the PUK code to the service provider so that you can keep it stored to avoid future mishaps.
Hope this helps ...:) Your feed back would be appreciated.
May 25, 2011 | Computers & Internet
Idk my PUK code for my LG KP500 and i cant call AT&T cause they are closed
hi,
You can locate your PUK usually it is included in your sim card kit when you purchase it. if you lost it already, this is the last thing we can do. Contact your operator customer care or visit them and ask for your PUK code and they are very glad to help you. they will ask you several questions pertaining to your account to verify if you are the real owner. You can also get it on-line on most operator if they have this service at their website if they are closed.
Follow this link for AT&T: http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&solutionId=KB33662
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Don't forget to rate me OK! thanks...
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM card. The phone will display the following error: "PUK blocked call operator."
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your SIM card Customer Care.
regards,
John
Jan 20, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
I need the PUK code
PUK code is a SIM specific code assigned by your service provider.
No way you can guess & enter it.
If you enter wrong code for three times, SIM gets completely blocked. You have to walk into your service provider outlet to get a replacement SIM card.
Most of the service providers will provide you the PUK code through customer care centre.
Call your customer care number through any of your friends mobile number of the same service provider, and ask for PUK code of your number...
Oct 29, 2009 | LG Vu CU920 Cellular Phone
Need puk code
puk code, personal unlocking key. It is sim card related / specific, if you take the sim card out from the phone, the phone will work with another sim card.
The puk comes up when the pin code has been entered wrong 3 times. To get the puk code for your sim card, you have to call the service provider of that sim card. They are the only ones who can provide you with the right puk code for that sim card.
The puk code may also have came with the documentation of the sim card, if its a prepaid card the puk code comes on the documents or on the box of the product.
if your unable to obtain the puk code, get a new sim card.
also entering the puk code wrong too many times will eventually ruin the sim card forcing you to buy or contact your service provider for a new sim card.
There are no puk code calculators or anything that we can do about it, you can buy premium assistance and you will get this same response. Theres no other solution.
You have to contact the phone service provider of that sim card or replace the sim card.
Can't help you even if you paid.
Sep 05, 2009 | Nokia 1600 Cellular Phone
Puk code
Call your service provider, they are the only persons who have a PUK code.
Mar 19, 2009 | LG Vu CU920 Cellular Phone
Sim card is blocked
the only way to fix this is to call customer service or go into a tmoblie store sorry. you can however save that PUK code for next time you need it lol
Nov 28, 2008 | RIM BlackBerry Curve 8310 Smartphone
I need a puk code for my orange phone
You can get your Orange PUK number only from the Orange service provider or customer care as PUK numbers for each SIM is different just like your SIM pin code, and it is only the Orange service provider who can give you this number.
Call up Orange customer services from your Mobile phone and ask them to provide you with a PUK code, after answering a few security details your PUK code will be given to you !
Oct 28, 2008 | Cell Phones
Cell Phones Logo
Top Motorola Cell Phones Experts
Jax Planet
Jax Planet
Resolution IT Dubai
Resolution IT Dubai
aliasger yq
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
