Question about Pentax Optio 555 Digital Camera
Spouse pull out memory card instead of pushing in first. Now can't get memory care competely back into slot; When pushed all the way down, about 3/16" still above slot. An fixes? Thanks, Eric
  • Anonymous Feb 06, 2011
    I had tried the previous suggestions before but to no avail. It would help if someone knew how the latching mechanism worked in this push to release lock and if there is any possibility of repair without disassembly.
    Thanks.
  • Anonymous Feb 09, 2011
    As I have said before, the answers I have received have been generic. This fix would apply to most cameras. I'm trying to find someone who has done this with with camera model and specific instructions. Trying to do otherwise will invite disaster.
    Thanks.
Anonymous
    President:
  • 1,566 Answers
There is a possibility that the memory card is not properly inserted. Or, the string that pushes the memory card is misaligned.
If that is the case, to avoid further damage on the unit, its best if you can contact the manufacturer.
Posted on Feb 09, 2011
Ekse
  • Pentax Master
  • 13,434 Answers
You will have to take apart the camera to see whats wrong with the card reader and then to correct the problem, it will be very difficult to try and fix it from the small memory card hole in the bottom of the camera.
taking it apart voids the warranty, but if done with great care it wont leave any marks on the camera and someone wouldn't be able to tell that it has been opened. ofcourse broken labels and such will be a dead giveaway.
To take apart the camera unscrew all the screws that you can from the outside, then notice the front and back of the camera, there is a crack or opening that you can slide your fingernail in on or use a plastic case opening tool or a plastic stick to go around the casing of the camera and release the plastic clips that hold the front and the back together.
when they come apart you will need to carefully disconnect any ribbon cables or similar that may be connected between the parts.
as the cameras case comes apart you should be able to see the card reader, if not you may have to take it apart a bit further.
once you get it visible, take a good look at it and insert the memory card, can you see what is blocking it from going in all the way? possibly theres a metallic part on the top or on the side that is out of position. you need to move it out from the way or back to its original position and it should let you put in the card.
it does not matter as far as I know if the ejection mechanism, works, if it doesn't work the camera should still be able to use the memory card without any problems aslong as it stays in the slot and doesn't drop out.
Posted on Feb 06, 2011
  • Ekse Feb 09, 2011
    You can not demand Specific assistance in this case as you are only paying us (the people who respond to you) 4$.
    You should take the camera to a repairer if you are so worried about it or buy a new one. The bottom line is, it is kind of standard the way these are put together, and with the instructions above you can't really go wrong.
  • Pentax Master
  • 17,130 Answers
Normally unless it is pushed the card will not release but if this was pulled out it is possible that the card holder or the card itself was damaged. So remove the card and invert the camera so as to face the slot downward to your palm . Now tap into the camera several times to extract any broken pieces from the sd card slot. If not try to see within with a card shaped probe- a credit card cut out will do- so as to free the space within. Now please counter check your card with a card reader or another camera or PC to confirm if this works fine.
If so try again or else you will need technical help to open the camera to clear the slot contacts.
Posted on Feb 05, 2011
I am thinking of adding memory to my Compaq Presario SR111ONX. I was looking for a schematic of the motherboard or a diagram showing the memory slots and how to add it.
Two long slots with tabs on each end... the hold the memory sticks vertical to the board.
Use your finger to gently move the tab away from the memory stick on both sides... after each tab has been moved away pull up firmly on the memory stick...note the position of the slot(s) on the side of the stick that goes into the slot. insert the replacement memory stick in the slot lining it up carefully and push down ... the tabs should go back into place on their own if the memory is seated properly.
Robert
Sep 19, 2008 | Compaq Computers & Internet
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
How to Re-seat the video card and memory
Step 1:
To re-set the memory or rams.
notice the Notch ?? this lines up with the notch of the ram socket on the main board
Step 2:
The highlighted slots which are Blue and black are the ram slots (ON THIS BOARD color may vary on yours but the shape and size is the same) Pull the clips apart, insert the Rams lining up the notches correctly (slots are labled Dimm1 Dimm 2 etc) start from one , th order doesnt matter and any slot will do but its good practice.. Firmly push the rams down into the slot and the clips will slide back in place and lock the rams in place.
Step 3:
FOR THE GRAPHICS CARD
notice the long single slot ?
it also has a notch on it the same as the graphics card,
line up the notches and push the graphics card in place, it will clip in,, Screw back in the back plate..
Step 4:
Thats it your done.
Dec 27, 2012 | Dell Dimension 3100 PC Desktop
Trying to remove graphics card from pci-express slot on ecs gf8100vm-m3 motherboard. How does the clip on the end work? It holds the card in and I cannot figure out how it releases.
You should be able to push down on the release clip/latch(similar to Memory ram sticks). Trying reaching under and pushing down while pulling up on the graphic card.
Mar 25, 2011 | Computers & Internet
How do I take out the memory card?
Hello there,
You should push the card down to eject itself up. Then just pull it out from the compartment.
Hope this helps. Please let me know. THank you for using FixYa.
Jan 23, 2011 | Casio EXILIM EXS7 Digital Camera
It is not accepting memory cards,instead it pushes it outwards.
Most probably your memory card slot is broken and spring inside is damaged so it pushes up so better change your memory card slot..!
Please let me know if you need any further assistance.
Kind regards
Roy
Dec 28, 2010 | Sony Ericsson W700i Cellular Phone
How to insert sandisk in laptop?
face up. gently push till it clicks. it should only fit in the slot one way. (make sure the slot is the same width as the card. Do not use the Larger slots. Typically you insert (gold) contacts down, and in first. to remove, push till you feel click, then pull. Be aware that some new micro SD cards have formats that older,( 2 years ago) laptops will not recognize. I think they are marked HD. or HC. Cards. Most of my devices Wont recognize this new format. Camera included. Cheers
Aug 24, 2010 | SanDisk 2GB microSD Memory Card
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Im having problems inserting the mic ro sd card in the lg shine
First of all, remove the back cover. The Micro SD slot is located underneath the SIM card slot. Hold the SD card with the metal connectors facing you and slide the card into the slot, metal connectors first, until it clicks in place. A logo of an SD card should then appear on the top of the screen.
Then to remove it, push it in and it will click and then pop back out
Oct 18, 2007 | LG Shine KE970 Cellular Phone
Pentax Optio 555 Digital Camera Logo
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
